[Solved] ChateauLTE6 - installed qcom-ac driver but can't connect
Hi all,
As above, with the addition that my laptop hangs at “getting network address” and doesn’t go any further.
When I check Winbox, I can see the laptop is registered under WiFi, but still doesn’t connect.
Heers my config
# 2025-11-19 18:27:43 by RouterOS 7.20.2
# software id = V4HN-RZG9
# model = D53G-5HacD2HnD&FG621-EA
# serial number = HEJ08SHFRZ5
add admin-mac=78:9A:18:90:5A:DE auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-n .width=20/40mhz \
    configuration.country="New Zealand" .mode=ap .ssid=Mikrotik disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp
set [ find default-name=wifi2 ] channel.band=5ghz-ac .width=20/40/80mhz \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=xx name="Hero Internet"
add apn=internet name=Default
add apn=xx name=Spark
add apn=xx name=2Degrees
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=Spark band=\
    1,3,7,8,28,40 network-mode=lte
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
add address-list=vpn change-tcp-mss=yes local-address=192.168.89.1 name=vpn \
    remote-address=vpn use-encryption=yes
add bridge=bridge interface=*6
add bridge=bridge interface=*7
set udp-timeout=10s
/interface l2tp-server server
set default-profile=vpn enabled=yes use-ipsec=required
add comment=defconf interface=lte1 list=WAN
/interface ovpn-server server
add mac-address=xx name=ovpn-server1
    192.168.88.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip cloud advanced
set use-local-address=yes
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=xx comment=Integritech disabled=yes list=Management
add address=xx.sn.mynetname.net comment=IntegriTech list=Management
    established,related,untracked
    invalid
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    in-interface-list=WAN protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 \
add action=accept chain=input comment="allow l2tp" dst-port=1701 \
add action=accept chain=input comment="Remote Access" dst-port=8291 \
    in-interface-list=WAN protocol=tcp src-address-list=Management
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ip ipsec profile
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh port=2202
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ppp secret
add name=vpn profile=vpn service=l2tp
/system clock
set time-zone-name=Pacific/Auckland
/system identity
set name=Vroom!
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
Any help would be much appreciated!
EDIT: Worked it out. WiFi wasn’t added to the bridge. Done, and works fine now. Cheers.
