[SOLVED] Clients of Station Bridge not getting DHCP
Ok, so I have this HAP ax2, and it’s connecting in station-bridge config without issue to my wireless network.
Clients on the ether ports of the HAP ax2 aren’t getting DHCP, though… the ether interfaces are just one big bridge. Any ideas?
Here’s the configuration, it’s pretty straightforward:
# 2024-01-14 21:19:28 by RouterOS 7.14beta6
# software id = WU29-BLCC
# model = C52iG-5HaxD2HaxD
# serial number = HEP08XS9X0H
add name=bridge1
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5805 .skip-dfs-channels=all .width=20mhz configuration.country="United States" .mode=station-bridge .ssid=Hector disabled=no
add name=LAN
add name=UPLINK
/interface wifi security
add authentication-types=wpa3-psk disabled=no encryption=ccmp-256,gcmp-256 name=sec1
/system logging action
add email-to=noc@noc.com name=email target=email
add bridge=bridge1 interface=LAN
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wifi1 list=UPLINK
/ip dhcp-client
add interface=wifi1
/system clock
set time-zone-name=America/New_York
/system identity
set name=livingroom-client-ap
/system logging
add action=email topics=critical,warning,account
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.62.14.1
/system package update
set channel=testing
Nope, you can’t add ports to bridge by using interface list, you have to add them one-by-one. E.g.
add bridge=bridge1 interface=wifi1
And then further down
you only add bridge1 interface to any interface list you might need (but for device to act as transparent gateway between local wired island and the rest of network via wireless hop you don’t need any interface lists IMO since you’re not using interface lists apart from incorrect use quoted above).
Yep, that was the issue. Thanks a lot.
I also removed DHCP client from the wifi1 interface and made it a static address for management, since DHCP client was unhappy with a passthrough interface being bound to it, which is no big deal.
Final, working, config:
# 2024-01-15 10:47:36 by RouterOS 7.14beta6
add name=bridge1
/interface wifi
set udp-timeout=10s
/ipv6 settings
add address=10.62.14.6/24 interface=wifi1 network=10.62.14.0
/system clock
/system identity
/system logging
/system note
/system ntp client
set enabled=yes
set channel=testing
