[solved] Default configuration, LTE ping but bridge does not
I’m trying to use LTE with a RBSXTR but without success. I ran the quick setup, set the PIN and APN, the device is correctly connected and I can ping from lte1 interface, but not from bridge, so devices connected via DHCP can’t access internet.
I didn’t changed anything in the configuration, except APN, PIN and admin account password …
I did try to change the NAT rules (to set the out interface to lte1) but without success
Here is my configuration :
# 2023-09-20 11:14:39 by RouterOS 7.11.2
# software id = 97M4-E1IV
# model = RBSXTR
# serial number = XXXXXX
add admin-mac=11:22:33:44:55 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=free use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=free band=""
/ip hotspot profile
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add comment=defconf interface=lte1 list=WAN
add address=192.168.188.1/24 comment=defconf interface=bridge network=192.168.188.0
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 gateway=192.168.188.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Paris
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes boot-os=router-os
/tool mac-server
/tool mac-server mac-winbox
And some more infos :
[admin@MikroTik] > tool/ping count=5 address=9.9.9.9 interface=lte1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 9.9.9.9                                    56  58 32ms503us
    1 9.9.9.9                                    56  58 40ms198us
    2 9.9.9.9                                    56  58 33ms474us
    3 9.9.9.9                                    56  58 30ms973us
    4 9.9.9.9                                    56  58 35ms807us
    sent=5 received=5 packet-loss=0% min-rtt=30ms973us avg-rtt=34ms591us max-rtt=40ms198us
[admin@MikroTik] > tool/ping count=5 address=9.9.9.9 interface=bridge
    0 9.9.9.9                                                      timeout
    1 9.9.9.9                                                      timeout
    2 9.9.9.9                                                      timeout
    3 192.168.188.1                              84  64 139ms266us host unreachable
    4 9.9.9.9                                                      timeout
    sent=5 received=0 packet-loss=100%
[admin@MikroTik] > ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, m - MODEM
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS       GATEWAY  DISTANCE
DAm 0.0.0.0/0         lte1            2
DAc (public ip from operator)/32  lte1            0
DAc 192.168.188.0/24  bridge          0
[admin@MikroTik] > ip/address/print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS           NETWORK        INTERFACE
;;; defconf
0   192.168.188.1/24  192.168.188.0  bridge
1 D (public ip from operator)/32  (public ip from operator) lte1
What is missing to have a correct internet access from the dhcp clients ?
Any tips to get it working would be really helpful !
Thank!
edit: I can’t delete the post but the issue is solved: the clients can access internet, I messed up something about DNS. So it seems it is normal that I can’t ping via bridge on public IP, I don’t understand why (when a DHCP client try to connect to internet, it comes from the bridge interface right ?)
