[SOLVED]Default route to Internet
I have a router (RB2011UiAS-RM) who has static IP and DNS addresses and is able to connect to Internet without any issues (ping tests).
I tried to use default network (192.168.88.0) with a laptop to communicate with the other network and I wasn’t able. I tried configurations of scope and target scope unsuccessfully.
I attach network flow.
any suggestions?
edit [solved] post #10
Do you have srcnat active for the WAN interface?
Can you post your NAT rules?
You can do this using the terminal with the command:
ip firewall nat print
If you’re not sure how to use the terminal then take a screen shot of the NAT config page: IP > Firewall > NAT.
Make sure you obscure any public IP info!
You need a masquerade rule and it is advisable to make dhcp server to provide all necessary ip settings to the lan connected devices.
/ip firewall nat src-address=192.168.88.0/24 action=masquerade out-interface=ether3 chain=src-nat
meaning
address incoming to router with address 192.168.88.0/24 will be source-nated
with technique masquerade (meaning it will use the outgoing address of interface) ether3.
Thanks for reply!
I currently have this conf:
[admin@MikroTik] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.88.1/24    192.168.88.0    bridge-local
 1   200.200.200.88/24  200.200.200.0   ether3
[admin@MikroTik] > /interface print where running
 #     NAME                                TYPE         MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 2  RS ether3                              ether       1500  1598       4074 4C:5E:0C:43:91:95
 4  RS ether5                              ether       1500  1598       4074 4C:5E:0C:43:91:97
11  R  bridge-local                        bridge      1500  1598            4C:5E:0C:43:91:94
[admin@MikroTik] > /ip dns static print
Flags: D - dynamic, X - disabled, R - regexp
 #     NAME                                                     ADDRESS        TTL
 0     router                                                   192.168.88.1        1d
[admin@MikroTik] > /ip dns print
                servers: 200.200.200.250
        dynamic-servers:
  allow-remote-requests: yes
    max-udp-packet-size: 4096
   query-server-timeout: 2s
    query-total-timeout: 10s
             cache-size: 2048KiB
          cache-max-ttl: 1w
             cache-used: 38KiB
[admin@MikroTik] > /ip firewall nat print
     chain=srcnat action=masquerade out-interface=sfp1-gateway
 1   ;;; default configuration
     chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=ether1-gateway
 2   chain=srcnat action=masquerade src-address=192.168.88.0/24 out-interface=ether3
and from the router I’m able to do this:
[admin@MikroTik] > ping http://www.lufthansa.com
HOST                                     SIZE TTL TIME  STATUS
172.229.169.118                            56  53 99ms
172.229.169.118                            56  53 98ms
but from my laptop I got this:
# ping http://www.lufthansa.com
PING e2929.g.akamaiedge.net (172.229.169.118) 56(84) bytes of data.
From router (192.168.88.1): icmp_seq=2 Redirect Host(New nexthop: 200.200.200.250)
From router (192.168.88.1): icmp_seq=4 Redirect Host(New nexthop: 200.200.200.250)
From router (192.168.88.1): icmp_seq=6 Redirect Host(New nexthop: 200.200.200.250)
# nslookup http://www.lufthansa.com
Server:		192.168.88.1
Address:	192.168.88.1#53
Non-authoritative answer:
http://www.lufthansa.com	canonical name = lufthansa.com.edgekey.net.
lufthansa.com.edgekey.net	canonical name = lufthansa.com.edgekey.net.globalredir.akadns.net.
lufthansa.com.edgekey.net.globalredir.akadns.net	canonical name = e2929.g.akamaiedge.net.
Address: 172.229.169.118
the browser in the laptop doesn’t navigate, so, currently it’s most related to a laptop misconfigure than the router, right?
This looks like your routing is setup wrong, can you please post the output from
ip route print
Also, you have too many masquerade rules, you should only have the
one, the others need to be removed.
my
ip route print
is:
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          200.200.200.250           1
 1 ADC  192.168.88.0/24    192.168.88.1    bridge-local              0
 2 ADC  200.200.200.0/24   200.200.200.88  bridge-local              0
about
, when I deleted 0 and 1 I not even got the Redirect Host message when pinged
I think part of the issue is that you public interface and private interface are on the same bridge.
Remove ether3 from bridge-local.
Then remove the public IP from bridge-local and add it to just ether3.
ok,now I have this:
[admin@MikroTik] /ip firewall nat> /ip route print
 0 ADC  192.168.88.0/24    192.168.88.1    ether5                    0
 1 ADC  200.200.200.0/24   200.200.200.88  ether3                    0
[admin@MikroTik] /ip firewall nat> /ip firewall nat print
 0 X ;;; default configuration
 1 X ;;; default configuration
     chain=srcnat action=masquerade out-interface=ether1-gateway
note 0 and 1 are disabled in nat.
with this conf I’m still unable to see 200.200.200.0/24 from 192.168.88.0/24
any suggestion?
update
with above configuration and even with rules 0 and 1 enabled I am able to ping 200.200.200.0/24 from 192.168.88.0/24, so it seems that problem was that both interfaces were on the same bridge.
Despite above, I am not able to ping 8.8.8.8, so currently I only can connect to router’s gateway and not beyond.
solved routing rule was needed
so, my config is:
[admin@MikroTik] /ip route> print
 1 ADC  192.168.88.0/24    192.168.88.1    ether5                    0
 2 ADC  200.200.200.0/24   200.200.200.88  ether3                    0
[admin@MikroTik] /ip firewall nat> print
not sure if disable 0 and 1 is needed
[admin@MikroTik] /ip route> /ip address print
 2   192.168.88.1/24    192.168.88.0    ether5
thanks for your help!
