[Solved] DMZ + PPTP
I have a mikrotik 433AH with basic config WAN, LAN1, LAN2.
LAN1 is a DMZ. When i switch off dst-nat (NAT rule) the PPTP VPN connection is working. But if i switch on DMZ the PPTP VPN is not working.
I use all services in mikrotik a dst-nat redirect rule (for example (8291, 22, 23, 1723) what i want to use besides of DMZ.
Does anyone have any ideas?
I restarted the router and everything was fine. I dont know what was the problem.
