[SOLVED] Dual wifi routes basic config
I want to use dual band Wifi configuration for my AX^3. I choose 5Ghz and 2Ghz, set some basic config like SSID and security but for some reason I can connect only to wifi1 5Ghz. I couldn’t find answer in google. In recent software update I see a lot of wifi improvements but I don’t see anything specific to my issue.
lags: R - RUNNING; S - SLAVE
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAX-L2MTU, MAC-ADDRESS
 #    NAME            TYPE       ACTUAL-MTU  L2MTU  MAX-L2MTU
 0 R  ether1          ether            1500   1568       9214
 1 RS ether2          ether            1500   1568       9214
 2 RS ether3          ether            1500   1568       9214
 3  S ether4          ether            1500   1568       9214
 4  S ether5          ether            1500   1568       9214
 5 RS ads             veth             1500
;;; defconf
 6 R  bridge          bridge           1500   1560
 7 R  docker          bridge           1500  65535
 8 R  lo              loopback        65536
 9 R  pppoe  pppoe-out        1492
10 RS wifi1           wifi             1500   1560       1560
11  S wifi2           wifi             1500   1560       1560
/system/package/print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME       VERSION  BUILD-TIME           SIZE
0 wifi-qcom  7.17.2   2025-02-06 09:10:24  10.2MiB
1 container  7.17.2   2025-02-06 09:10:24  64.1KiB
2 routeros   7.17.2   2025-02-06 09:10:24  12.0MiB
One thing that brought my attention is that the 2nd interface is not running
/interface/wifi/print
0 MBR wifi1  ap                  sid_name  20/40/80mhz
1 MB  wifi2  ap                  sid_name2  20/40mhz
Wifi interfaces will only show as running when something is connected.
Since you do not show the relevant parts of config it’s a guessing game.
Please provide export of wifi part of config.
Here is exported file:
2025_02_cfg_part.rsc (4.1 KB)
(I cleaned up some sections, let me know if I provide all required information)
/container mounts
add dst=/opt/adguardhome/work name=adguard-work src=\
    /usb1/adguard-home/opt/adguardhome/work
add dst=/opt/adguardhome/conf name=adguard-conf src=\
    /usb1/adguard-home/opt/adguardhome/conf
add admin-mac=G4:1E:57:76:37:G5 auto-mac=no comment=defconf name=bridge
add name=docker
set [ find default-name=ether1 ] mac-address=28:A6:F7:FD:41:4F
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=\
    szarlotka_cynamonowa disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid=\
    sernik_brzoskwiniowy disabled=no security.authentication-types=\
    wpa-psk,wpa2-psk .ft=yes .ft-over-ds=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-imperium \
    user=8010
/interface veth
add address=192.168.11.2/24 gateway=192.168.11.1 gateway6="" name=ads
/disk
set usb1 media-interface=bridge media-sharing=yes smb-sharing=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=docker interface=ads
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
I am not seeing a glaring error on wifi part except I don’t see a country setting ?
Where is dhcp server for lan ?
Where are ip settings for bridge ?
Dns ?
I unchecked WPA/PSK option so the only auth type is WPA2/PSK and it worked. Is it possible that some devices can not work correctly with that setting(WPA+WPA2)? If it’s something different I can provide lan, bridge and dns information.
That’s certainly possible.
Also, lots of IoT devices don’t want to connect to network with WPA3 as option, even if WPA2 can be used as well.
