After reading almost all posts about how to configure hairpin NAT, I still can’t make it work.
I have a CCR1009-7G-1C-1S+ MikroTik router.
The public IP is provided by my ISP with DHCP.
From internet I can access my web server without any problem. From LAN I can’t access my web server.
Interface ether1 is connected to Internet.
Interface VLAN ont-vl832 is created on interface ether1 because my ISP use VLAN 832 for internet data.
Bridge br-wan si created with interface ont-vl832 because I need to set TOS on DHCP packets to get my public IP from my ISP.
This is what happens from LAN when i try to access the webserver :
curl -k https://my_public_ip
curl: (7) Failed to connect to my_public_ip port 443: Connection refused
Here is the tcpdump trace :
11:43:35.692012 IP 192.168.1.YY.51996 > my_public_ip.443: Flags [S], seq 2525450066, win 29200, options [mss 1460,sackOK,TS val 1921652487 ecr 0,nop,wscale 7], length 0
11:43:35.692671 IP my_public_ip.443 > 192.168.1.YY.51996: Flags [R.], seq 0, ack 2525450067, win 0, length 0
Here is my config on the MikroTik router :
VLAN :
/interface vlan print
# NAME MTU ARP VLAN-ID INTERFACE
0 R ;;; VLAN832 on ether1
ont-vl832 1500 enabled 832 ether1
BRIDGE :
/interface bridge print
name="br-wan" mtu=auto actual-mtu=1500 l2mtu=1576 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:XX:YY:ZZ protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
NAT :
/ip firewall nat print
0 chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=br-wan
1 chain=dstnat action=dst-nat to-addresses=192.168.1.XX protocol=tcp in-interface=br-wan dst-port=80
2 chain=dstnat action=dst-nat to-addresses=192.168.1.XX protocol=tcp in-interface=br-wan dst-port=443
FILTER :
/ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; FastTrack
chain=forward action=fasttrack-connection connection-state=established,related
2 ;;; Established, Related
chain=forward action=accept connection-state=established,related
3 ;;; Drop invalid
chain=forward action=drop connection-state=invalid log=yes log-prefix="invalid"
4 ;;; Drop tries to reach not public addresses from LAN
chain=forward action=drop dst-address-list=not_in_internet in-interface=combo1 out-interface=!combo1 log=yes log-prefix="!public_from_LAN"
5 ;;; Drop incoming packets that are not NATted
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 out-interface=!ether1 log=yes log-prefix="!public_from_LAN"
6 ;;; Drop incoming from internet which is not public IP
chain=forward action=drop src-address-list=not_in_internet in-interface=ether1 log=yes log-prefix="!public"
7 ;;; Drop packets from LAN that do not have LAN IP
chain=forward action=drop src-address=!192.168.1.0/24 in-interface=combo1 log=yes log-prefix="LAN_!LAN"
ADRESS-LIST :
/ip firewall address-list print
Flags: X - disabled, D - dynamic
# LIST ADDRESS CREATION-TIME TIMEOUT
0 ;;; RFC6890
not_in_internet 0.0.0.0/8 may/27/2018 17:18:41
1 ;;; RFC6890
not_in_internet 172.16.0.0/12 may/27/2018 17:18:41
2 ;;; RFC6890
not_in_internet 192.168.0.0/16 may/27/2018 17:18:41
3 ;;; RFC6890
not_in_internet 10.0.0.0/8 may/27/2018 17:18:41
4 ;;; RFC6890
not_in_internet 169.254.0.0/16 may/27/2018 17:18:41
5 ;;; RFC6890
not_in_internet 127.0.0.0/8 may/27/2018 17:18:41
6 ;;; Multicast
not_in_internet 224.0.0.0/4 may/27/2018 17:18:41
7 ;;; RFC6890
not_in_internet 198.18.0.0/15 may/27/2018 17:18:41
8 ;;; RFC6890
not_in_internet 192.0.0.0/24 may/27/2018 17:18:41
9 ;;; RFC6890
not_in_internet 192.0.2.0/24 may/27/2018 17:18:41
10 ;;; RFC6890
not_in_internet 198.51.100.0/24 may/27/2018 17:18:41
11 ;;; RFC6890
not_in_internet 203.0.113.0/24 may/27/2018 17:18:41
12 ;;; RFC6890
not_in_internet 100.64.0.0/10 may/27/2018 17:18:41
13 ;;; RFC6890
not_in_internet 240.0.0.0/4 may/27/2018 17:18:41
14 ;;; 6to4 relay Anycast [RFC 3068]
not_in_internet 192.88.99.0/24 may/27/2018 17:18:43
Thanks for help !
