I can’t get my brand new hEX PoE to work with an Approved Optics copper SFP. I get no link light, however “interface ethernet monitor sfp1” shows that the SFP is detected (see below).
I’ve tried two different SFPs, two different cables, and connecting both to a gig port on another computer and also to ether5 on the Mikrotik itself.
Any suggestions for what else to try? Does this device only support fibre SFPs? Or was I perhaps unlucky enough to get a faulty device?
Many thanks,
Brian.
[admin@MikroTik] > /interface ethernet monitor sfp1
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-lose: no
sfp-type: SFP-or-SFP+
sfp-link-length-copper: 100m
sfp-vendor-name: US Critical
sfp-vendor-part-number: GLC-T-US
sfp-vendor-revision: B2
sfp-vendor-serial: USXTXV33704
sfp-manufacturing-date: 14-07-22
sfp-wavelength: 16653.93nm
sfp-dwdm-channel-spacing: 1Ghz
eeprom: 0000: 03 04 00 00 00 00 08 00 00 00 00 01 0d 00 00 00 ........ ........
0010: 00 00 64 00 55 53 20 43 72 69 74 69 63 61 6c 20 ..d.US C ritical
0020: 20 20 20 20 01 00 17 6a 47 4c 43 2d 54 2d 55 53 ...j GLC-T-US
0030: 20 20 20 20 20 20 20 20 42 32 20 20 41 0c c1 84 B2 A...
0040: 00 10 00 00 55 53 58 54 58 56 33 33 37 30 34 20 ....USXT XV33704
0050: 20 20 20 20 31 34 30 37 32 32 20 20 00 00 00 23 1407 22 ...#
0060: 00 00 08 a2 cd 1e 04 28 3d a6 e2 94 ce be b9 d9 .......( =.......
0070: ff 7c 2d 00 00 00 00 00 00 00 00 00 0f 7a 3f 19 .|-..... .....z?.
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
[admin@MikroTik] > /system resource print
uptime: 4m28s
version: 6.37.4 (bugfix)
build-time: Dec/13/2016 12:12:04
factory-software: 6.36
free-memory: 107.2MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V5.0
cpu-count: 1
cpu-frequency: 800MHz
cpu-load: 31%
free-hdd-space: 5.5MiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 51
write-sect-total: 1718
bad-blocks: 0%
architecture-name: mipsbe
board-name: hEX PoE
platform: MikroTik
