I setup a basic hotspot but when a user is logged, his traffic downs to 2,6kbs (fast.com). If I disable the hotspot the traffic of the client is 20Mbps. Do you know where it could come from ?
The setup is basic, a dhcp on ether2-master, client are connecting with wifi (unifi AP) which have static ip addresses. I made binding of thoses static ip for the hotspot. As in the mikrotik wiki I setup with a rate limit tx/rx to 512000/512000. But if I remove this rate limit, I got no more traffic speed.
Here is mikrotik configuration :
Networks :
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.88.1/24 192.168.88.0 ether2-master
1 D 192.168.1.135/24 192.168.1.0 ether1
DNS :
[admin@MikroTik] > ip dns print
servers: 192.168.88.1
dynamic-servers: 192.168.1.254,192.168.1.255
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 468KiB
Pools
[admin@MikroTik] > ip pool print
# NAME RANGES
0 dhcp 192.168.88.31-192.168.88.254
1 vpn 192.168.89.2-192.168.89.255
DHCP
[admin@MikroTik] > ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 defconf ether2-master dhcp 10m
Hotspot
[admin@MikroTik] > ip hotspot print
Flags: X - disabled, I - invalid, S - HTTPS
# NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 X hotspot1 ether2-master dhcp hsprof1 5m
Hotpsot Profile
[admin@MikroTik] > ip hotspot profile print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name=""
html-directory=flash/hotspot html-directory-override="" rate-limit=""
http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=mac,http-chap
mac-auth-mode=mac-as-username mac-auth-password="" split-user-domain=no
use-radius=no
1 name="hsprof1" hotspot-address=192.168.88.1 dns-name="lerelais.sml"
rate-limit="512000/512000" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no
use-radius=no
Hotspot User
[admin@MikroTik] > ip hotspot user print
Flags: * - default, X - disabled, D - dynamic
# SERVER NAME ADDRESS PROFILE UPTIME
0 * ;;; counters and limits for trial users
default-t... 0s
1 admin test 14m17s
Hotspot User Profile
I just give the profile 1, in 0 it’s the default profile (the final one I would like to use, but I have script associated)
1 name="test" address-pool=dhcp idle-timeout=none keepalive-timeout=2m
status-autorefresh=1m shared-users=1000 add-mac-cookie=yes
mac-cookie-timeout=3d rate-limit="512000/512000" address-list=""
transparent-proxy=no
Hotspot binding
[admin@MikroTik] > ip hotspot ip-binding print
Flags: X - disabled, P - bypassed, B - blocked
# MAC-ADDRESS ADDRESS TO-ADDRESS SERVER
0 P 78:0C:B8:6D:E8:72 192.168.88.22 192.168.88.22 hotspot1
1 P 44:D9:E7:F2:22:11 192.168.88.12 192.168.88.12 hotspot1
2 P 80:2A:A8:C0:24:3C 192.168.88.11 192.168.88.11 hotspot1
3 P 80:2A:A8:19:C9:21 192.168.88.13 192.168.88.13 hotspot1
4 P B8:27:EB:C4:EB:67 192.168.88.21 192.168.88.21 hotspot1
192.168.88.1x are the unifi AP and 2x are a raspi and my laptop to not be blocked ![]()
Thank you for your help.
