I have a RB952Ui-5ac2nD-US (yes, the locked american version), and want to keep it from using some channels. Is there a way to create a channel black list, to keep the router from using them?
No. You can only explicitly declare the allowed frequencies.
Works for me. Where do I set it?
Thanks,
http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#Overview
See scan-list property.
Excelent! Problem solved! Many thanks. ![]()
yeah, that is fantastic feature. (but for ~ complex scan list doing them manually - not easy and there was also limitation in lenght, due to possible complexity of some).
so you can either filter-out known source of interference or prevent affecting sensitive by Your gear gear.
My problem is a little different: I’m brazilian, and just bought a supposed international hAP ac lite. Turned out to be the american one. Usually I would just return the unit, but I need it now, and there isn’t another one I could buy in time.
Fortunately the brazilian regulation is quite alike the american one. I just had to shave one channel off. Not the best solution, but…
