Scroll further down for the solution
I have connected and powered a Huawei E122 to a RB493G. It is showing under resources/usb, and I can get PPP info from it. I have been able to run AT commands on the device.
When I set the PPP interface to connect, it gets stuck on dialing out status. I have enabled debug logging and not much is outputted.
Can you help with this at all please? I see E122 is not on the compatible hardware list, so maybe this is the problem.
log: (changed by admin=enable/disable PPP interface)
11:46:36 async,ppp,info 3g-modem: initializing modem…
11:46:36 async,ppp,info 3g-modem: dialing out…
11:48:37 async,ppp,info 3g-modem: initializing modem…
11:48:37 async,ppp,info 3g-modem: dialing out…
11:48:53 async,ppp,info 3g-modem: dialing out…
11:48:53 async,ppp,info 3g-modem: disconnected
11:48:53 async,ppp,info 3g-modem: initializing…
11:48:53 async,ppp,info 3g-modem: reseting link…
11:48:53 system,info device changed by admin
11:51:28 async,ppp,info 3g-modem: dialing out…
11:51:28 async,ppp,info 3g-modem: disconnected
11:51:28 async,ppp,info 3g-modem: initializing…
11:51:28 async,ppp,info 3g-modem: reseting link…
11:51:28 system,info device changed by admin
11:53:46 async,ppp,info 3g-modem: dialing out…
11:53:46 async,ppp,info 3g-modem: disconnected
11:53:46 async,ppp,info 3g-modem: initializing…
11:53:46 async,ppp,info 3g-modem: reseting link…
11:53:46 system,info device changed by admin
11:54:18 async,ppp,info 3g-modem: dialing out…
11:54:18 async,ppp,info 3g-modem: disabled
11:54:18 system,info device changed by admin
11:54:21 async,ppp,info 3g-modem: initializing…
11:54:21 async,ppp,info 3g-modem: reseting link…
11:54:21 system,info device changed by admin
11:54:21 async,ppp,info 3g-modem: dialing out…
11:54:56 async,ppp,info 3g-modem: dialing out…
11:54:56 async,ppp,info 3g-modem: disabled
11:54:56 system,info device changed by admin
11:55:56 async,ppp,info 3g-modem: initializing…
11:55:56 async,ppp,info 3g-modem: reseting link…
11:55:56 system,info device changed by admin
11:55:56 async,ppp,info 3g-modem: dialing out…
USB Info:
[admin@MikroTik] /system resource usb> pr
DEVICE VENDOR NAME SPEED
0 2:1 RB400 EHCI 480 Mbps
1 2:2 HUA WEI Huawei Mobile 480 Mbps
2 1:1 RB400 OHCI 12 Mbps
PPP client:
[admin@MikroTik] /interface ppp-client> pr
0 ;;; 3G Modem on-demand connection
name=“3g-modem” max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
data-channel=0 info-channel=0 apn=“3internet” pin=“” user=“”
password=“” profile=3internet phone=“” dial-command=“*99#”
modem-init=“ATQ0 V1 E1 S0=0 &C1 &D2” null-modem=no dial-on-demand=no
add-default-route=no use-peer-dns=no keepalive-timeout=10 allow=pap
PPP profile 3internet:
1 name=“3internet” remote-ipv6-prefix-pool=(unknown) use-ipv6=no use-mpls=no
use-compression=no use-vj-compression=no use-encryption=no
only-one=default change-tcp-mss=no
PPP Info:
[admin@MikroTik] /interface ppp-client> info 0
status: ready
pin-status: no password required
functionality: full
gprs-class: A - GPRS & GSM simultaneous
manufacturer: NOT SUPPORT
model: E122
revision: NOT SUPPORT
serial-number: 356881030xxxxxx
current-operator: 3 UK
access-technology: 3G
signal-strengh: -77 dBm
frame-error-rate: n/a
– [Q quit|D dump|C-z pause]
Kind Regards,
Tony
