Good Day,
I am a part time sysadmin working in a small repair shop which is divided across two buildings, having two independent network connections. In both of the buildings I have Mikrotik RB751U-2HnD running ROS 6.37.5. They are connected via PPTP as we have SAMBA running for file sharing between buildings. Yesterday I had a minor issue with one of our Windows 7 clients, after a reboot I noticed that the IP address on the client is given from the range of our first router. Please see the attached logs from both routers:
Router 1 - https://pastebin.com/raw/AuNibFYc
Router 2 - https://pastebin.com/raw/WHPQ6Eyf
DHCP lease on Router 2 - https://pastebin.com/raw/536ThQp7
As you can see in the last log, some of my clients are given a ciaddr which is outside the scope of the second router’s dhcp pool.
Thank you!
