Solved - Intel AX200 doesn’t connect in AX mode — only works in AC
I have an Intel(R) Wi-Fi 6 AX200 160MHz on my ASUS motherboard, and I’m using a MikroTik hAP ax2.
When the wireless mode is set to AC, it works normally and connects fine.
But when I set it to AX or Auto, the device doesn’t even connect or appear in the list of available networks.
I’m currently on RouterOS 7.20.1.
Only switching back to AC solves the issue.
Has anyone else experienced this behavior?
Thanks.
Limit your AP to UNII1/2 (up to channel 124 iirc).
Most intel cards can't do unii 3.
I'm guessing it's this old topic again :sweat_smile:
https://community.intel.com/t5/Wireless/AX210-and-BE200-only-5Ghz-AX-with-20mhz-Channel-width/m-p/1550533
Thanks for the link.
My frequency is set to 5180 MHz (channel 36), but I still can’t connect in AX mode — it only works when I switch to AC.
Maison
Then it's probably a different issue.
Is this just a problem with this ax200? Or other clients too?
Can you share a config? (Remove private information)
Perhaps it is your ax200 settings.
(On Windows 10)
Get to the network adapters page. (one way)
Control panel, Network and internet, view network status and tasks, change adapter settings
Choose the Wi-Fi adapter then properties
Up the top choose configure, then advanced, and go through the options available.
802.11n/ac/ax Wireless mode might be worth looking at.
interface/wifi> print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
0 M BR ;;; Z
default-name="wifi1" name="wifi1" mtu=1500 l2mtu=1560 mac-address=XXXXXXX arp-timeout=auto
radio-mac=XXXXXX
configuration.mode=ap .ssid="XXX 5G" .country=Brazil
security.authentication-types=wpa2-psk,wpa3-psk
datapath.bridge=bridge1
channel.frequency=5180
1 M BR ;;;
default-name="wifi2" name="wifi2" mtu=1500 l2mtu=1560 mac-address=48:A9:8A:66:29:92 arp-timeout=auto
radio-mac=XXXXXX
configuration.mode=ap .ssid="XXX 2G" .country=Brazil
channel.frequency=2412 .width=20mhz
I have another router in the shed at my house. I discovered that disabling its Wi-Fi makes my main router work again, even though my PC connects to this Wi-Fi with a signal strength of -85...
Config hap ac now in
1 M BX ;;;
default-name="wifi2" name="wifi2" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto
radio-mac=XXXXXX
configuration.mode=ap .ssid="XXXXXX-5G" .country=Brazil
channel.frequency=5220
Update
I changed the channel on my other AC router from 5220 to 5745, (-85) signal and now my main ax2 (-39) router is working as it should. Thanks for your help, everyone!
