[SOLVED] IP Output from Mikrotik
after i upgraded my mikrotik to 6.33
and then in output connection show up a connection IP Add 169.254.169.254:80 from my IP Public Add
but if im downgrade my Mikrotik to 6.32.3 then that output connection doesnt show up again
even that, my internet connection is worked as usual.
im just corious what ip address is that.
SOLVED
Everyone who is noticing unusual traffic on your router - we have managed to reproduce this issue and we will fix it as soon as possible. The router is checking the ssh key for amazon cloud installation environments, a feature coming later.
As a temporary workaround you can use this solution:
/ip route add distance=1 dst-address=169.254.0.0/16 type=blackhole
