[solved] IPSec networks didnt work with Cisco router
:frowning:
Parameters given from big hosting provider (He has cisco router):
Phase 1:
  • encryption: 3DES
  • hashing: MD5
  • DH-group: 2
  • Lifetime: 86400s
  • ISAKMP keep-alivces: enabled
  • authentication: preshared key
Phase 2:
  • encryption: 3DES
  • hashing: MD5
  • perfect-forwarding-secrecy: no
  • Lifetime: 28800s
  • networks to encrypt:
  • 10.10.110.0/24 <=> 172.16.0.0/16
  • 10.10.110.0/24 <=> 10.0.3.0/16
With my cisco it works correctly. With my mikrotik doesnt. Why?
If you are from mikrotik I can give you access, to find out problem.
but on attached screenshot PFS Group is set to ‘modp1024’.
HTH,
I tried also this, but still doesnt work. :frowning:
Do you have more than one IP address on your WAN interface?
If yes, use the first one in your IPSec policy.
And log shows that your local and remote ID doesn’t match (lines 5 to 10).
HTH,
"And log shows that your local and remote ID doesn’t match (lines 5 to 10). "
ID is generated form network , perhaps…
encrypted network 10.0.3.0/16 was the mistake.
I have bad information from our provider. I tried 10.0.3.0/24 and it works !!!
Thank you very much.
karma +1
