[SOLVED]IPV6 Link local
I remove by accident my auto generated link local addr on my interface.
Is it a way to re-generate it without reboot ?
And this action is not in undo history :frowning:
thanks
disable/enable interface.
i’m not on the console but behind this interface, not a good solution :slight_smile:
so?
run command
disable ether1; enable ether1
it will instantly disable and enable, probably won’t even disconnect you.
working perfectly :slight_smile:
thanks
thank you works perfectly 2019
