[SOLVED] Local DNS not working over Wireguard
I’m new to RouterOS/mikrotik, but I have some experience with networking and Linux.
I set up Wireguard on my hAP ax3 and my phone connects to it without issues. I want to be able to use my local DNS (a pi hole), but it doesn’t work:
  • when I set the pihole’s IP address as dns server nothing resolves on the phone
  • when I set 8.8.8.8 as the DNS server on the phone’s wireguard config, everything works
The problem is that I want to be able to use my DNS because I also have local records for local hosts that I want to connect to.
Do I need to have a firewall rule? Is there anything I’m missing?
Hard to say without seeing the config, what needs to be done.
Also the settings on the phone
/export file=anynameyouwish ( minus router serial number, any public WANIP information,keys etc. )
Sorry for the very late reply. Life happens.
It was a classical PEBKAC problem… although it was more of a PEBHAP (problem exists between hands and phone) - I had my android phone set to “Use custom DNS” -when I disabled that it went straight to my DNS.
Thanks for letting us know!! Good info for future use!!
