Greetings,
I have a 2 internet links connected to my mikrotik, both are 10mbps. The main uplink have monthly traffic limitation, and the secondary link is unlimited but with a very inferior quality.
Today, when I find someone using a lot of bandwidth, I manually create a mangle rule to apply the secondary internet routing mark to his IP address.
Any ideas/suggestions of how to do this automatically for ips that downloaded/uploaded more than 500mb in the last 24 hours?
Thank you!
eduardosilva:
Greetings,
Thank you!
if they have static ips try going into ip-routes…rules and insert the ip select wan u want and … should work
Hello ffernandes,
They do not have static ips. It’s a “public” network without any hotspot, just dhcp.
Thank you
Just as an update and for future reference, I solved this writing a custom script (my first script);
/ip firewall filter add action=passthrough chain=monitor dst-address=192.168.10.2
/ip firewall filter add action=passthrough chain=monitor dst-address=192.168.10.3
/ip firewall filter add action=passthrough chain=monitor dst-address=192.168.10.4
/ip firewall filter add action=passthrough chain=monitor dst-address=192.168.10.249
Wrote the monitoring script (schedule every 00:30)
:global subnet "192.168.10."
:global maxbytes 305044184
:for i from=2 to 249 do={
:delay 2
:local bytes [/ip firewall filter get [find chain=monitor dst-address="$subnet$i"] bytes];
:if ( $bytes > $maxbytes ) do={
:local count 0
foreach X in=[ /ip firewall mangle find where src-address="$subnet$i" ] do={:set count 1 }
:if ( count = 0 ) do={
/ip firewall mangle add action=mark-routing chain=high-usage-users comment="Regra Automatica" new-routing-mark=adsl passthrough=no src-address="$subnet$i" }
And the cleanup script schedule to run once a day:
/ip firewall filter reset-counters [find chain=monitor]
/ip firewall mangle remove [find chain=high-usage-users ]
