Thanks for your reply @holvoetn,
I’m currently running 7.14.3 for the issues you alude to. I did try 7.19.2, but that was still pretty much unusable. I’m keeping an eye on both the forums and changelogs to see whether there are any significant changes likely to provide the required fixes. Not so much a fan of beta or alpha releases as I’ve been burned before, though not with MT releases.
I understand there’s a slew of changes coming, think I’d prefer to wait until 7.21 becomes stable.
# 2025-07-05 19:23:43 by RouterOS 7.14.3
# software id = 43JE-CDHX
# model = C52iG-5HaxD2HaxD
# serial number = xxxxxxxx
add admin-mac=xxxxxxxx auto-mac=no comment=BRIDGE name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] comment=WAN-LTE
set [ find default-name=ether2 ] comment=WAN-DHCP
set [ find default-name=ether3 ] comment=WAN-PPPoE
set [ find default-name=ether4 ] comment=LAN
set [ find default-name=ether5 ] comment=LAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz comment=Primary configuration.country=\
"New Zealand" .mode=ap .ssid=NeverUMind disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp \
.passphrase=xxxxxxxx
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=all \
.width=20/40mhz-eC comment=Primary configuration.country="New Zealand" \
.mode=ap .ssid=NeverUMind disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .encryption=ccmp .passphrase=xxxxxxxx
add comment=Guest configuration.mode=ap .ssid=NeverUMind-Guest \
datapath.client-isolation=yes disabled=no mac-address=xxxxxxxx \
master-interface=wifi1 name=wifi3 security.authentication-types=\
master-interface=wifi2 name=wifi4 security.authentication-types=\
add comment=IoT configuration.hide-ssid=yes .mode=ap .ssid=iot5 \
master-interface=wifi1 name=wifi5 security.authentication-types=\
add comment=IoT configuration.hide-ssid=yes .mode=ap .ssid=iot2 \
master-interface=wifi2 name=wifi6 security.authentication-types=\
wpa-psk,wpa2-psk .encryption=ccmp .passphrase=xxxxxxxx
/interface wireguard
add comment=back-to-home-vpn listen-port=35960 mtu=1420 name=back-to-home-vpn \
private-key="xxxxxxxx"
/interface vlan
add comment="VLAN 10 - DHCP" interface=ether2 name=DHCP_v10 vlan-id=10
add comment="VLAN 10 - PPPoE" interface=ether3 name=vlan10 vlan-id=10
/interface pppoe-client
add add-default-route=yes comment="WAN PPPoE" disabled=no interface=vlan10 \
name=pppoe-1 password=password use-peer-dns=yes user=username
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=2.4G-IoT name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
add comment=2.4G-Guest name=dhcp_pool2 ranges=10.10.20.2-10.10.20.254
add comment=5G-Guest name=dhcp_pool3 ranges=10.10.20.2-10.10.20.254
add comment=5G-IoT name=dhcp_pool4 ranges=10.10.10.2-10.10.10.254
add comment=Primary name=defconf_dhcp ranges=10.10.0.2-10.10.0.254
add address-pool=defconf_dhcp comment=Primary interface=bridge lease-time=10m \
name=defconf
add address-pool=dhcp_pool1 comment="2.4G IoT" interface=wifi6 lease-time=10m \
name=dhcp1
add address-pool=dhcp_pool2 comment="2.4G Guest" interface=wifi4 lease-time=\
10m name=dhcp2
add address-pool=dhcp_pool3 comment="5G Guest" interface=wifi3 lease-time=10m \
name=dhcp3
add address-pool=dhcp_pool4 comment="5G IoT" interface=wifi5 lease-time=10m \
name=dhcp4
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
/interface l2tp-server server
set default-profile=default one-session-per-host=yes
add comment=LTE interface=ether1 list=WAN
add comment=PPPoE interface=pppoe-1 list=WAN
add comment=DHCP interface=DHCP_v10 list=WAN
add address=10.10.10.1/24 comment="2.4G IoT" interface=wifi6 network=\
10.10.10.0
add address=10.10.20.1/24 comment="5G Guest" interface=wifi3 network=\
10.10.20.0
add address=10.10.20.1/24 comment="2.4G Guest" interface=wifi4 network=\
10.10.20.0
add address=10.10.10.1/24 comment="5G IoT" interface=wifi5 network=10.10.10.0
add address=10.10.0.1/24 comment=Primary interface=bridge network=10.10.0.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf interface=ether2
add address=10.10.0.0/24 dns-server=1.1.1.3,1.0.0.3 gateway=10.10.0.1
add address=10.10.10.0/24 comment="IoT Subnet" dns-server=1.1.1.3,1.0.0.3 \
gateway=10.10.10.1
add address=10.10.20.0/24 comment="Guest Subnet" dns-server=1.1.1.3,1.0.0.3 \
gateway=10.10.20.1
set allow-remote-requests=yes
/ip dns static
add address=10.10.10.1 comment=defconf name=router.lan
"Allow trusted subnet and wireguard for config" in-interface-list=LAN
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
in-interface-list=!LAN
invalid
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=drop chain=forward in-interface=wifi6 out-interface=bridge
add action=drop chain=forward in-interface=wifi5 out-interface=bridge
add action=drop chain=forward in-interface=wifi4 out-interface=bridge
add action=drop chain=forward in-interface=wifi3 out-interface=bridge
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2206
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Pacific/Auckland
/system identity
set name="Home Router AX"
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=time.cloudflare.com
/system scheduler
add comment="5G Enable" interval=1d name=Enable_WiFi1 on-event=\
Enable_Primary5G policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2025-06-22 start-time=06:30:00
add comment="2G Enable" interval=1d name=Enable_WiFi2 on-event=\
Enable_Primary2G policy=\
add comment="5G Disable" interval=1d name=Disable_WiFi1 on-event=\
Disable_Primary5G policy=\
start-date=2025-06-22 start-time=23:00:00
add comment="2G Disable" interval=1d name=Disable_WiFi2 on-event=\
Disable_Primary2G policy=\
/system script
add dont-require-permissions=no name=Enable_Primary5G owner=itechadmin \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="interface wifi enable wifi1"
add dont-require-permissions=no name=Enable_Primary2G owner=itechadmin \
source="interface wifi enable wifi2"
add dont-require-permissions=no name=Disable_Primary5G owner=itechadmin \
source="interface wifi disable wifi1"
add dont-require-permissions=no name=Disable_Primary2G owner=itechadmin \
source="interface wifi disable wifi2"
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
