[SOLVED] New PPTP VPN connection not working
Hi all,
I have 4 VPN connections to my main Mikrotik RB750GL in the UK, I have 2 RB750GLs located in Switzerland and elsewhere in the UK which connect over PPTP fine and subnets route fine. I have an ASUS RT-AC68U in China which connects fine and requires some manual route entries to stop it using the UK as a default destination, but otherwise subnets route ok.
The 4th VPN connection from another Mikrotik RB750GL also in China connects for 65 seconds, and won’t route subnets.
I have followed the instructions here for setting up the VPN:
https://www.mikrotik.com/documentation/manual_2.7/Interface/PPTP.html
The configuration of the UK and Chinese Mikrotik’s are detailed here:
http://pastebin.ca/2948777
And finally here is a trace of the pptp connection …
15:41:32 pptp,info TCP connection established from xx.xx.xx.xx
15:41:32 pptp,debug,packet rcvd Start-Control-Connection-Request from xx.xx.xx.xx
15:41:32 pptp,debug,packet     protocol-version=0x0100
15:41:32 pptp,debug,packet     framing-capabilities=2
15:41:32 pptp,debug,packet     bearer-capabilities=0
15:41:32 pptp,debug,packet     maximum-channels=0
15:41:32 pptp,debug,packet     firmware-revision=1
15:41:32 pptp,debug,packet     host-name=MikroTik
15:41:32 pptp,debug,packet     vendor-name=MikroTik
15:41:32 pptp,debug,packet sent Start-Control-Connection-Reply to xx.xx.xx.xx
15:41:32 pptp,debug,packet     result-code=1
15:41:32 pptp,debug,packet     error-code=0
15:41:32 pptp,debug,packet rcvd Outgoing-Call-Request from xx.xx.xx.xx
15:41:32 pptp,debug,packet     call-id=0
15:41:32 pptp,debug,packet     call-serial-number=0
15:41:32 pptp,debug,packet     minimum-bps=2400
15:41:32 pptp,debug,packet     maximum-bps=10000000
15:41:32 pptp,debug,packet     bearer-type=3
15:41:32 pptp,debug,packet     framing-type=2
15:41:32 pptp,debug,packet     packet-recv-window-size=100
15:41:32 pptp,debug,packet     packet-processing-delay=0
15:41:32 pptp,debug,packet     phone-number-length=0
15:41:32 pptp,debug,packet     phone-number=
15:41:32 pptp,debug,packet     subaddress=
15:41:32 pptp,ppp,debug <1679>: LCP lowerup
15:41:32 pptp,ppp,debug <1679>: LCP open
15:41:32 pptp,debug,packet sent Outgoing-Call-Reply to xx.xx.xx.xx
15:41:32 pptp,debug,packet     call-id=1679
15:41:32 pptp,debug,packet     peers-call-id=0
15:41:32 pptp,debug,packet     cause-code=0
15:41:32 pptp,debug,packet     connect-speed=100000
15:41:32 pptp,debug,packet     physical-channel-id=0
15:41:33 pptp,ppp,debug,packet  <1679>: rcvd LCP ConfReq id=0x27
15:41:33 pptp,ppp,debug,packet    <mru 1460>
15:41:33 pptp,ppp,debug,packet    <magic 0x782101a4>
15:41:33 pptp,ppp,debug,packet  <1679>: sent LCP ConfReq id=0x1
15:41:33 pptp,ppp,debug,packet    <magic 0x1c67cb35>
15:41:33 pptp,ppp,debug,packet    <auth  mschap2>
15:41:33 pptp,ppp,debug,packet  <1679>: sent LCP ConfAck id=0x27
15:41:33 pptp,ppp,debug,packet  <1679>: rcvd LCP ConfAck id=0x1
15:41:33 pptp,ppp,debug <1679>: LCP opened
15:41:33 pptp,ppp,debug,packet  <1679>: sent CHAP Challenge id=0x1
15:41:33 pptp,ppp,debug,packet     <challenge len=16>
15:41:33 pptp,ppp,debug,packet     <name MikroTik>
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd CHAP Response id=0x1
15:41:34 pptp,ppp,debug,packet     <response len=49>
15:41:34 pptp,ppp,debug,packet     <name xxxx>
15:41:34 pptp,ppp,info,account xxxx logged in, 172.16.1.8
15:41:34 pptp,ppp,debug,packet  <1679>: sent CHAP Success id=0x1
15:41:34 pptp,ppp,debug,packet     S=7C42AE8A60F7721D9CE1B5ABB5510EE2F2C938BF
15:41:34 pptp,ppp,info <pptp-xxxx>: authenticated
15:41:34 pptp,ppp,debug <1679>: IPCP lowerup
15:41:34 pptp,ppp,debug <1679>: IPCP open
15:41:34 pptp,ppp,debug,packet  <1679>: sent IPCP ConfReq id=0x1
15:41:34 pptp,ppp,debug,packet     <addr 172.16.1.7>
15:41:34 pptp,ppp,debug <1679>: IPV6CP lowerup
15:41:34 pptp,ppp,debug <1679>: IPV6CP open
15:41:34 pptp,ppp,debug,packet  <1679>: sent IPV6CP ConfReq id=0x1
15:41:34 pptp,ppp,debug,packet     <interface-identifier 0:0:f0:68d>
15:41:34 pptp,ppp,debug <1679>: MPLSCP lowerup
15:41:34 pptp,ppp,debug <1679>: MPLSCP open
15:41:34 pptp,ppp,debug,packet  <1679>: sent MPLSCP ConfReq id=0x1
15:41:34 pptp,ppp,debug <1679>: BCP open
15:41:34 pptp,ppp,debug <1679>: CCP lowerup
15:41:34 pptp,ppp,debug <1679>: CCP open
15:41:34 pptp,ppp,debug,packet  <1679>: sent CCP ConfReq id=0x1
15:41:34 pptp,ppp,debug,packet     <mppe 1000040>
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd IPCP ConfReq id=0x7b
15:41:34 pptp,ppp,debug,packet     <addr 0.0.0.0>
15:41:34 pptp,ppp,debug,packet  <1679>: sent IPCP ConfNak id=0x7b
15:41:34 pptp,ppp,debug,packet     <addr 172.16.1.8>
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd IPV6CP ConfReq id=0xc8
15:41:34 pptp,ppp,debug,packet     <interface-identifier 0:0:0:a>
15:41:34 pptp,ppp,debug,packet  <1679>: sent IPV6CP ConfAck id=0xc8
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd MPLSCP ConfReq id=0x37
15:41:34 pptp,ppp,debug,packet  <1679>: sent MPLSCP ConfAck id=0x37
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd CCP ConfReq id=0x3b
15:41:34 pptp,ppp,debug,packet  <1679>: sent CCP ConfAck id=0x3b
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd IPCP ConfAck id=0x1
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd IPV6CP ConfAck id=0x1
15:41:34 pptp,ppp,debug <1679>: IPV6CP opened
15:41:34 pptp,ppp,info <pptp-xxxx>: connected
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd MPLSCP ConfAck id=0x1
15:41:34 pptp,ppp,debug <1679>: MPLSCP opened
15:41:34 pptp,ppp,debug,packet  <1679>: rcvd CCP ConfAck id=0x1
15:41:34 pptp,ppp,debug <1679>: CCP opened
15:41:34 pptp,ppp,info <pptp-xxxx>: using encoding - MPPE128 stateless
15:41:35 pptp,ppp,debug,packet  <1679>: rcvd IPCP ConfReq id=0x7c
15:41:35 pptp,ppp,debug,packet     <addr 172.16.1.8>
15:41:35 pptp,ppp,debug,packet  <1679>: sent IPCP ConfAck id=0x7c
15:41:35 pptp,ppp,debug <1679>: IPCP opened
15:42:23 pptp,debug,packet rcvd Echo-Request from yy.yy.yy.yy
15:42:23 pptp,debug,packet     identifier=1830
15:42:23 pptp,debug,packet sent Echo-Reply to yy.yy.yy.yy
15:42:23 pptp,debug,packet     result-code=1
15:42:23 pptp,debug,packet     error-code=0
15:42:24 ovpn,info China-ASUS-Ovpn: terminating...
15:42:24 ovpn,info China-ASUS-Ovpn: disconnected
15:42:33 pptp,ppp,debug,packet  <1679>: sent LCP EchoReq id=0x0
15:42:33 pptp,ppp,debug,packet     <magic 0x1c67cb35>
15:42:34 pptp,ppp,debug <1679>: LCP missed echo reply
15:42:34 pptp,ppp,debug,packet  <1679>: sent LCP EchoReq id=0x1
15:42:34 pptp,ppp,debug,packet     <magic 0x1c67cb35>
15:42:35 pptp,ppp,debug <1679>: LCP missed echo reply
15:42:35 pptp,ppp,debug,packet  <1679>: sent LCP EchoReq id=0x2
15:42:35 pptp,ppp,debug,packet     <magic 0x1c67cb35>
15:42:36 pptp,ppp,debug <1679>: LCP missed echo reply
15:42:36 pptp,ppp,debug,packet  <1679>: sent LCP EchoReq id=0x3
15:42:36 pptp,ppp,debug,packet     <magic 0x1c67cb35>
15:42:37 pptp,ppp,debug <1679>: LCP missed echo reply
15:42:37 pptp,ppp,debug,packet  <1679>: sent LCP EchoReq id=0x4
15:42:37 pptp,ppp,debug,packet     <magic 0x1c67cb35>
15:42:38 pptp,ppp,debug <1679>: LCP missed echo reply
15:42:38 pptp,ppp,debug <1679>: LCP lowerdown
15:42:38 pptp,ppp,debug <1679>: LCP closed
15:42:38 pptp,ppp,debug <1679>: CCP lowerdown
15:42:38 pptp,ppp,debug <1679>: CCP closed
15:42:38 pptp,ppp,debug <1679>: BCP lowerdown
15:42:38 pptp,ppp,debug <1679>: BCP down event in starting state
15:42:38 pptp,ppp,debug <1679>: IPCP lowerdown
15:42:38 pptp,ppp,debug <1679>: IPCP closed
15:42:38 pptp,ppp,debug <1679>: IPV6CP lowerdown
15:42:38 pptp,ppp,debug <1679>: IPV6CP closed
15:42:38 pptp,ppp,debug <1679>: MPLSCP lowerdown
15:42:38 pptp,ppp,debug <1679>: MPLSCP closed
15:42:38 pptp,ppp,info <pptp-xxxx>: terminating... - peer is not responding
15:42:38 pptp,ppp,debug <1679>: LCP down event in starting state
15:42:38 pptp,ppp,info,account xxxx logged out, 66 162 238 10 11
15:42:38 pptp,ppp,info <pptp-xxxx>: disconnected
I’ve compared this with the connection established by the Mikrotik in Switzerland and there is no difference in the startup log other than session id#s …
15:50:48 pptp,info TCP connection established from yy.yy.yy.yy
15:50:48 pptp,debug,packet rcvd Start-Control-Connection-Request from yy.yy.yy.yy
15:50:48 pptp,debug,packet     protocol-version=0x0100
15:50:48 pptp,debug,packet     framing-capabilities=2
15:50:48 pptp,debug,packet     bearer-capabilities=0
15:50:48 pptp,debug,packet     maximum-channels=0
15:50:48 pptp,debug,packet     firmware-revision=1
15:50:48 pptp,debug,packet     host-name=MikroTik
15:50:48 pptp,debug,packet     vendor-name=MikroTik
15:50:48 pptp,debug,packet sent Start-Control-Connection-Reply to yy.yy.yy.yy
15:50:48 pptp,debug,packet     result-code=1
15:50:48 pptp,debug,packet     error-code=0
15:50:48 pptp,debug,packet rcvd Outgoing-Call-Request from yy.yy.yy.yy
15:50:48 pptp,debug,packet     call-id=0
15:50:48 pptp,debug,packet     call-serial-number=0
15:50:48 pptp,debug,packet     minimum-bps=2400
15:50:48 pptp,debug,packet     maximum-bps=10000000
15:50:48 pptp,debug,packet     bearer-type=3
15:50:48 pptp,debug,packet     framing-type=2
15:50:48 pptp,debug,packet     packet-recv-window-size=100
15:50:48 pptp,debug,packet     packet-processing-delay=0
15:50:48 pptp,debug,packet     phone-number-length=0
15:50:48 pptp,debug,packet     phone-number=
15:50:48 pptp,debug,packet     subaddress=
15:50:48 pptp,ppp,debug <1688>: LCP lowerup
15:50:48 pptp,ppp,debug <1688>: LCP open
15:50:48 pptp,debug,packet sent Outgoing-Call-Reply to yy.yy.yy.yy
15:50:48 pptp,debug,packet     call-id=1688
15:50:48 pptp,debug,packet     peers-call-id=0
15:50:48 pptp,debug,packet     cause-code=0
15:50:48 pptp,debug,packet     connect-speed=100000
15:50:48 pptp,debug,packet     physical-channel-id=0
15:50:48 pptp,ppp,debug,packet  <1688>: rcvd LCP ConfReq id=0x39
15:50:48 pptp,ppp,debug,packet    <mru 1460>
15:50:48 pptp,ppp,debug,packet    <magic 0x74906448>
15:50:48 pptp,ppp,debug,packet  <1688>: sent LCP ConfReq id=0x1
15:50:48 pptp,ppp,debug,packet    <magic 0x28156061>
15:50:48 pptp,ppp,debug,packet    <auth  mschap2>
15:50:48 pptp,ppp,debug,packet  <1688>: sent LCP ConfAck id=0x39
15:50:48 pptp,ppp,debug,packet  <1688>: rcvd LCP ConfAck id=0x1
15:50:48 pptp,ppp,debug <1688>: LCP opened
15:50:48 pptp,ppp,debug,packet  <1688>: sent CHAP Challenge id=0x1
15:50:48 pptp,ppp,debug,packet     <challenge len=16>
15:50:48 pptp,ppp,debug,packet     <name MikroTik>
15:50:48 pptp,ppp,debug,packet  <1688>: rcvd CHAP Response id=0x1
15:50:48 pptp,ppp,debug,packet     <response len=49>
15:50:48 pptp,ppp,debug,packet     <name yyyy>
15:50:48 pptp,ppp,info,account yyyy logged in, 172.16.1.6
15:50:48 pptp,ppp,debug,packet  <1688>: sent CHAP Success id=0x1
15:50:48 pptp,ppp,debug,packet     S=4F7353A347DB4FC5B8335C07B7E8B4A24C9FFF58
15:50:48 pptp,ppp,info <pptp-yyyy>: authenticated
15:50:48 pptp,ppp,debug <1688>: IPCP lowerup
15:50:48 pptp,ppp,debug <1688>: IPCP open
15:50:48 pptp,ppp,debug,packet  <1688>: sent IPCP ConfReq id=0x1
15:50:48 pptp,ppp,debug,packet     <addr 172.16.1.5>
15:50:48 pptp,ppp,debug <1688>: IPV6CP lowerup
15:50:48 pptp,ppp,debug <1688>: IPV6CP open
15:50:48 pptp,ppp,debug,packet  <1688>: sent IPV6CP ConfReq id=0x1
15:50:48 pptp,ppp,debug,packet     <interface-identifier 0:0:f0:696>
15:50:48 pptp,ppp,debug <1688>: MPLSCP lowerup
15:50:48 pptp,ppp,debug <1688>: MPLSCP open
15:50:48 pptp,ppp,debug,packet  <1688>: sent MPLSCP ConfReq id=0x1
15:50:48 pptp,ppp,debug <1688>: BCP open
15:50:48 pptp,ppp,debug <1688>: CCP lowerup
15:50:48 pptp,ppp,debug <1688>: CCP open
15:50:48 pptp,ppp,debug,packet  <1688>: sent CCP ConfReq id=0x1
15:50:48 pptp,ppp,debug,packet     <mppe 1000040>
15:50:48 pptp,ppp,debug,packet  <1688>: rcvd IPCP ConfReq id=0x11
15:50:48 pptp,ppp,debug,packet     <addr 0.0.0.0>
15:50:49 pptp,ppp,debug,packet  <1688>: sent IPCP ConfNak id=0x11
15:50:49 pptp,ppp,debug,packet     <addr 172.16.1.6>
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd IPV6CP ConfReq id=0x9
15:50:49 pptp,ppp,debug,packet     <interface-identifier 0:0:0:a>
15:50:49 pptp,ppp,debug,packet  <1688>: sent IPV6CP ConfAck id=0x9
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd MPLSCP ConfReq id=0x9
15:50:49 pptp,ppp,debug,packet  <1688>: sent MPLSCP ConfAck id=0x9
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd CCP ConfReq id=0x9
15:50:49 pptp,ppp,debug,packet     <mppe 1000040>
15:50:49 pptp,ppp,debug,packet  <1688>: sent CCP ConfAck id=0x9
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd IPCP ConfAck id=0x1
15:50:49 pptp,ppp,debug,packet     <addr 172.16.1.5>
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd IPV6CP ConfAck id=0x1
15:50:49 pptp,ppp,debug,packet     <interface-identifier 0:0:f0:696>
15:50:49 pptp,ppp,debug <1688>: IPV6CP opened
15:50:49 pptp,ppp,info <pptp-yyyy>: connected
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd MPLSCP ConfAck id=0x1
15:50:49 pptp,ppp,debug <1688>: MPLSCP opened
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd CCP ConfAck id=0x1
15:50:49 pptp,ppp,debug <1688>: CCP opened
15:50:49 pptp,ppp,info <pptp-yyyy>: using encoding - MPPE128 stateless
15:50:49 pptp,ppp,debug,packet  <1688>: rcvd IPCP ConfReq id=0x12
15:50:49 pptp,ppp,debug,packet  <1688>: sent IPCP ConfAck id=0x12
15:50:49 pptp,ppp,debug <1688>: IPCP opened
Why can’t I route the Chinese subnets? and why won’t the link stay up for more than 65 seconds?
Some more details on the issue …
I have replaced the ASUS with another Mikrotik and configured it to use the same pptp user. This Mikrotik also fails to connect intermittently over pptp.
Sometimes I will get a perfect pptp link which stays up for days and allows me to route my 192.168 subnets, but if I do something as innocuous as “/ip route set gateway=pptp-uk numbers=16,17” then the pptp link fails, and goes into a loop of connecting for 65secs, dropping, and reconnecting. Whilst its looping like this I cant route my 192.168 subnets.
Why would something as unrelated as changing a route cause pptp to fail in this way?
(The only thing that has changed recently is that I upgraded all Mikrotiks to 6.27, and the one in the UK is now missing the routeros-mipsbe-6.27 package).
Doh! - Just worked out why the router’s in China didn’t work, especially when touching the routing tables.
I had a routing entry to “jump the wall” for a range of IP address in the UK, but my pptp-server was in that range. So sometimes routing would work and sometimes not, depending upon whether or not the pptp-client module was trying to contact the pptp-server recursively via its own ppp link or correctly via the ISP.
Did you solve this ?
How ?
