Does anyone know of a Linux native app that could be used as a drop in alternative to Notepad++?
I’ve tried to install the snap version on a fresh Fedora install but it only initiates the Wine compatibility layer but the app itself fails to launch. Winbox 3 via snap works fine.
I’ll also want to use the language syntax with the Notepad++ alternative if pos too.
A common problem of “switchers”. You want to use Linux/macOS/any_other_os like Windows. No, it won’t work well. Use the OS where your habits and software are available and suits you best. If you like Notepad++ — just use Windows. E.g. nowadays me can’t use Windows because it counter-productive for me, I loss around 30% of productivity plus countless nerve cells. However, I used Windows including XP, then switched to Mac and never looked back (well, I looked, but after 1 hour of “looking” each new version I celebrated I don’t use Windows anymore :-). In the meantime I used a lot of Linux desktop distros. So, if you feel that Linux software or the concepts are not for you, e.g. you tried a week, a month and feel uncomfortable, just don’t.
As a straight reply I may recommend to look at Sublime. Many Linux users love it (but I cannot use because feel it uncomfortable). Also try to look at different IDEs. It’s not as lightweight as notepad, but… Maybe VS Code? But its plugins are super-buggy, personally I don’t recommend it, however a lot of popularity.
We are admins here, and everyone use what he likes the best, but on servers de-facto standard is vim/nano.
Fedora was always a “test site” for RedHat Enterprise Linux. So don’t expect much from this OS.
Thanks heaps for the detailed info. I was previously using Linux Mint Debian edition (deb12), however it seemed like Network Manager wasn’t prepared to play nice with L2TP configs so I opted for a distro with a faster updating schedule. I haven’t used Fedora before, and after doing a bit of digging decided to give it a go. So far, so good. I like it so far. Seems faster and less clunky. Having said that, I’m just in the process of downloading the latest Debian (13) live edition and will have a play with that too. Maybe Fedora will be a short stop over. Lol.
