has anybody problem with nv2 and client freeze? We have problem to use nv2 on some our APs, bacause of client freeze. If we disable and enable wireless, client is suddenly ok. ROS v is 6.18, new wireless package enabled, ROS is the same on AP and client. If we use nstreme, no freezes at all, but we want to use nv2 because we have better throuput and latency …
Does anybody have a solution for theese?
please describe your freezing detection methodics.[/quote]
It is simple, our customer calls, that internet is not working … everything what we do, is disable and enable him on AP and everything is than ok. This is not happening if there is nstreme or simple 802.11, only NV2 do this …
what wireless hardware are you using?
Please make sure that you also upgrade the Routboard firmware to the latest version.
What wireless configuration you are using.
Try to reset the wireless interface configuration to the default settings and then report back.
Wireless almost everywhere RB52Hn, or RB52, and APs are RB433AH or RB433L. Yes we do upgrade firmware also too, always with the upgrade of ROS.
Where should I reset configuration on AP or on client?
CPE is mostly SXT or RB711 or RB911, i upgraded yesterday one site to 6.18 and customer also to 6.18 with newest firmware, so far so good … will report later …
asimko, please contact support@mikrotik.com so we could get support output files from the time when that happens and maybe access your devices remotely.
