[Solved] OpenVPN Client (Mikrotik RouterOS) connecting to OpenVPN server (Debian/Linux)
I have some issues with making MT to work with OpenVPN server (Debian). I can make successfull connection to OVPN server, but traffic is not routed through OVPN server. Here is my configuration.
Setup
OpenVPN server (Debian/Linux) configuration
# cat /etc/openvpn/server.conf
local 95.2.171.3
port 1194
proto tcp
dev tun
ca ca.crt
cert server.crt
key server.key
dh dh.pem
server 10.8.0.0 255.255.255.0
ifconfig-pool-persist ipp.txt
client-config-dir ccd
route 192.168.81.0/24 255.255.255.0
keepalive 10 120
tun-mtu 1500
mssfix 1450
cipher AES-256-CBC
auth sha1
persist-key
persist-tun
status /var/log/openvpn-status.log
log-append /var/log/openvpn.log
verb 5
crl-verify /etc/openvpn/easy-rsa/pki/crl.pem
# cat /etc/openvpn/ccd/client
iroute 192.168.81.0 255.255.255.0 10.8.0.2
ifconfig-push 10.8.0.2 10.8.0.1
# cat /proc/sys/net/ipv4/ip_forward
1
# netstat -an | grep 1194
tcp        0      0 95.2.171.3:1194       0.0.0.0:*               LISTEN
tcp        0      0 95.2.171.3:1194       81.190.190.100:62973    ESTABLISHED
# ifconfig
eth0   Link encap:Ethernet  HWaddr 20:cf:30:f2:a8:76
          inet addr:95.2.171.3  Bcast:95.2.171.31  Mask:255.255.255.224
          inet6 addr: fe80::22cf:30ff:fef2:a876/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:255189 errors:0 dropped:0 overruns:0 frame:0
          TX packets:333054 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:34521411 (32.9 MiB)  TX bytes:367074147 (350.0 MiB)
          Interrupt:26 Base address:0x8000
lo       Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:15579 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15579 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1326071 (1.2 MiB)  TX bytes:1326071 (1.2 MiB)
tun0   Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.8.0.1  P-t-P:10.8.0.2  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:57 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6669 (6.5 KiB)  TX bytes:504 (504.0 B)
# netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
10.8.0.2        0.0.0.0         255.255.255.255 UH        0 0          0 tun0
95.2.171.0    0.0.0.0         255.255.255.224 U         0 0          0 eth0
192.168.81.0    10.8.0.2        255.255.255.0   UG        0 0          0 tun0
10.8.0.0        10.8.0.2        255.255.255.0   UG        0 0          0 tun0
0.0.0.0         95.2.171.30   0.0.0.0         UG        0 0          0 eth0
# iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -d 127.0.0.0/8 -i !lo -j REJECT --reject-with icmp-port-unreachable
-A INPUT -i tun0 -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -p tcp -m tcp --dport 1194 -j ACCEPT
-A INPUT -m limit --limit 5/min -j LOG --log-prefix "iptables denied: " --log-level 7
-A INPUT -j REJECT --reject-with icmp-port-unreachable
-A OUTPUT -j ACCEPT
# iptables -t nat -S
-P PREROUTING ACCEPT
-P POSTROUTING ACCEPT
-P OUTPUT ACCEPT
-A POSTROUTING -s 10.8.0.0/24 -j SNAT --to-source 95.2.171.3
# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_req=1 ttl=55 time=12.9 ms
64 bytes from 8.8.8.8: icmp_req=2 ttl=55 time=12.8 ms
This is all my config on OpenVPN Server (Debian/Linux).
OpenVPN Client side (Mikrotik RouterOS 6) configuration
/interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1600       4076 D4:CA:6D:31:14:F4
 1   S ether2                              ether            1500  1598       2028 D4:CA:6D:31:14:F5
 2   S ether3                              ether            1500  1598       2028 D4:CA:6D:31:14:F6
 3   S ether4                              ether            1500  1598       2028 D4:CA:6D:31:14:F7
 4   S ether5                              ether            1500  1598       2028 D4:CA:6D:31:14:F8
 5  RS wlan1                               wlan             1500  1600            D4:CA:6D:31:14:F9
 6  R  bridge1                             bridge           1500  1598            D4:CA:6D:31:14:F5
 7  R  ovpn-out1                           ovpn-out         1500                  FE:3E:27:7D:61:8C
 /interface bridge print
 0  R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled mac-address=D4:CA:6D:31:14:F5 protocol-mode=rstp priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE    BRIDGE        PRIORITY  PATH-COST    HORIZON
 0 I  ether2       bridge1                       0x80         10       none
 1 I  ether3       bridge1                       0x80         10       none
 2 I  ether4       bridge1                       0x80         10       none
 3 I  ether5       bridge1                       0x80         10       none
 4    wlan1        bridge1                       0x80         10       none
 /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.81.1/24    192.168.81.0    bridge1
 1 D 192.168.7.200/24   192.168.7.0     ether1
 2 D 10.8.0.2/32        10.8.0.1        ovpn-out1
 /ip firewall nat print
 0    chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=ether1 log=no log-prefix=""
 /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          192.168.7.1               0
 1 ADC  10.8.0.1/32        10.8.0.2        ovpn-out1                 0
 2 ADC  192.168.7.0/24     192.168.7.200   ether1                    0
 3 ADC  192.168.81.0/24    192.168.81.1    bridge1                   0
 /interface ovpn-client print
 0  R name="ovpn-out1" mac-address=FE:3E:27:7D:61:8C max-mtu=1500 connect-to=195.13.171.3 port=1194 mode=ip user="client" password="" profile=default certificate=Client auth=sha1 cipher=aes256 add-default-route=no
 /ping 10.8.0.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 10.8.0.1                                   56  64 6ms
    1 10.8.0.1                                   56  64 9ms
    2 10.8.0.1                                   56  64 7ms
    3 10.8.0.1                                   56  64 6ms
    sent=4 received=4 packet-loss=0% min-rtt=6ms avg-rtt=7ms max-rtt=9ms
As you can see, I can ping OpenVPN server from Mikrotik. But when I use internet from Local PC it shows 81.190.190.100 IP address, not the one I would like to see - OpenVPN servers IP - 95.2.171.3.
I can successfully ping/traceroute to 10.8.0.1 from Laptop (192.168.81.100/24), but cannot understand why it’s not routed through VPN tunnel. I think I’m missing something with routing either on server (Linux) or client (mikrotik).
Thanks for your help! I’m playing whit this for a while now, and cannot get it running :frowning:
Have a good day!
You’re trying to go full tunneling to access the Internet. The issue is with your routing table on MK.
The default gateway points to your modem and you can’t change that because then it won’t be able to reach the Internet.
Put a new default route pointing to your ovpn server address (the internal one not the public) and this default route associate it with a routing mark. Then mark Packets coming from the interface facing your computer with the same routing mark. Like this:
/ip route add gateway=10.8.0.1 routing-mark=default-ovpn
/ip firewall mangle add chain=prerouting in-interface=LAN action=mark-routing new-routing-mark=default-ovpn
You’ll also need to change sysctl on Linux to allow routing and configure iptables to do masquerading.
Enviado desde mi MotoE2(4G-LTE) mediante Tapatalk
Got my VPN setup working!!
Thanks!
