Hi everyone! I have some questions about OSPF areas and PPPoE. Im training with a virtual lab using GNS3 before deploy it in a real enviroment.
We have the next scenario:
Our network are in bridge mode with only one router (Gw Router) acting as a PPPoE Server for all clients.
I was configured the basic OSPF network showed in the above diagram.
We have some public class C networks given us by our ISP configured on “Gw Router” in “ether2” interface… as example:
- Pool A: 60.60.60.0/24
- Pool B: 70.70.70.0/24
- Pool C: 80.80.80.0/24
- Pool D: 90.90.90.0/24
I want to split a class C networks we have in multiple subnets and use one of these subnets for PPPoE clients in OSPF environment.
For example I want to take the “Pool D” and divide it into multiple subnets / 28 and use the 90.90.90.240/28 subnet for OSPF
I made a basic configuration and i have full ip connectivity between all OSPF routers that make up the network, but can not get customers “PPPoE A” and “B PPPoE” go on internet
I explain the basic configuration of OSPF on each router to see if you can help me get to solve my doubts.
R1:
/ip addresses
ether1: 172.16.0.2/24
ether2: 10.0.0.1/30
loopback: 10.255.255.1/32
Dst: 0.0.0.0/0 - Gateway: 172.16.0.1
/routing ospf interface
ether2, type=default
/routing ospf instance
router-id=10.255.255.1, distribute-default=as type 1, redistribute-connected=as type1
/routing ospf networks
network=10.0.0.0/30, area=backbone
R2:
/ip addresses
ether1: 10.0.0.2/30
ether2: 10.0.0.5/30
loopback: 10.255.255.2/32
ether1, type=default
router-id=10.255.255.2, distribute-default=never, redistribute-connected=as type1
network=10.0.0.4/30, area=backbone
R3:
/ip addresses
ether1: 10.0.0.6/30
ether2: 10.100.100.1/24
loopback: 10.255.255.3/32
ether2, type=broadcast, passive=yes
router-id=10.255.255.3, distribute-default=never, redistribute-connected=as type1
network=10.100.100.0/24, area=pppoe
network=90.90.90.240/28, area=pppoe
/routing ospf areas
0.0.0.0, name=backbone, type=default
0.0.0.1, name=pppoe, type=stub
/routing ospf areas range
Would it be correct all this configuration or I’m making mistakes?
How would you configure the OSPF network and bridge network to assign customer “PPPoE Client A” customer “PPPoE B” a public IP address within the range 90.90.90.240/28 and had internet access through the main router that is within the bridged network?
Thanks!
