[SOLVED] Port redirect, how?
Good afternoon.
I am sorry for my EnglishI use translator
A router RB1200, I want to redirect the port 80 on the server in the internal network.
Here are the rules:
chain=dstnat action=netmap to-addresses=10.x.x.x to-ports=80 protocol=tcp dst-address=109.x.x.x dst-port=80
chain=srcnat action=src-nat to-addresses=109.x.x.x src-address=10.x.x.x
But in apache (access.log) i see ip adress of RB1200 in internal network
Example:
10.x.x.x - - [27/Jan/2013:07:33:07 +0200] “GET /%28X%281%29S%28ctqhkweqwvo4or45zp1ig045%29%29/forms/GuestBook.aspx?MenuID=40&AspxAutoDetectCookieSupport=1 HTTP/1.0” 404 18952 “http://www.mysite.ua/(X(1)S(ctqhkweqwvo4or45zp1ig045))/forms/GuestBook.aspx?MenuID=40&AspxAutoDetectCookieSupport=1” “Opera/9.80 (Windows NT 5.1; Edition Ukraine Local) Presto/2.12.388 Version/12.10”
I can not see who is trying to break my site, I do not see attacker IP. Оnly access from the router.
That may be due to a srcnat/masquerade. Please post entire “/ip firewall nat”.
It might look like this:
chain=srcnat action=masquerade
…and to work the way you want, it should look like this:
chain=srcnat action=masquerade out-interface=ether1
If ether1 is not your WAN interface, change that.
[admin@cassiopeia] /ip firewall nat> print
 0   ;;; Masq on old network 192.168.30.0/24
     chain=srcnat action=masquerade out-interface=ether9-bridge
 1   ;;; Masq to internet
     chain=srcnat action=masquerade out-interface=ether10-wan
 2   chain=srcnat action=masquerade out-interface=ether1-sw-to-net10
 3   ;;; Masq ToHOME
     chain=srcnat action=masquerade out-interface=toHome
 4   ;;; rdp to PN1
     chain=dstnat action=dst-nat to-addresses=192.168.30.118 to-ports=3389 protocol=tcp in-interface=ether10-wan dst-port=33890
 5   ;;; dst-nat to Dude
     chain=dstnat action=dst-nat to-addresses=10.10.10.14 to-ports=88 protocol=tcp in-interface=ether10-wan dst-port=88
 6   ;;; RDP to HELIOS
     chain=dstnat action=dst-nat to-addresses=10.10.10.20 to-ports=3389 protocol=tcp in-interface=ether10-wan dst-port=33891
 7   ;;; to WEB server
     chain=dstnat action=netmap to-addresses=10.10.10.10 to-ports=80 protocol=tcp dst-address=109.x.y.z dst-port=80
 8   ;;; from WEB server
     chain=srcnat action=src-nat to-addresses=109.z.y.z src-address=10.10.10.10
9 X ;;; Web-to-proxy-redirect
     chain=dstnat action=dst-nat to-addresses=10.10.10.1 to-ports=3128 protocol=tcp in-interface=ether1-sw-to-net10 dst-port=80
7,8 rules are netmap to my web server
Which interface is your server on?
My server included in the switch that turned on to port ether1-sw-to-net10
Remove this rule:
I’m disable this rule. Now there is no access to the web server
Check your firewall in the server. Insure it accepts port 80 requests from everywhere, not just your localnet.
[14:59]root@pegasus:~# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
It does not help
If the dstnat works with that masquerade and does not work without it, you have a firewall or routing problem somewhere. Are you certain the default gateway in your server is correct?
On the server really was not the right route, I changed it and it worked. Thank you very much. I fought with this problem 2 weeks
93.126.xx.yy - - [04/Feb/2013:15:15:25 +0200] "GET / HTTP/1.1" 200 6983 "http://mysite.kiev.ua/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:18.0) Gecko/20100101 Firefox/18.0"
Thank you very much!
What changes did you make? Did you change the default gateway on server?
What changes did you make to your firewall rules so it solved the issue. Could you please include the changes you made.
