I am trying to setup a PPPoE client connection to my ISP over a VDSL line. My router is a RB3011UiAS connected to a Draytek Vigor V130 running in bridged mode. The V130 is synchronized with the other endpoint and does show me a running VDSL line on the physical layer. When I setup the PPPoE connection to the ISP I am using the parameters as suggested by them. The connection seems to be established for about a second and then its gone again…
The log entry look as follows:
21:48:20 pppoe,ppp,debug PPPoE-Inexio: LCP opened
21:48:20 pppoe,ppp,info PPPoE-Inexio: authenticated
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPCP lowerup
21:48:20 pppoe,ppp,debug,packet PPPoE-Inexio: sent IPCP ConfReq id=0xf1
21:48:20 pppoe,ppp,debug,packet <addr 0.0.0.0>
21:48:20 pppoe,ppp,debug,packet <ms-dns 0.0.0.0>
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPCP open
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPV6CP open
21:48:20 pppoe,ppp,debug PPPoE-Inexio: MPLSCP lowerup
21:48:20 pppoe,ppp,debug,packet PPPoE-Inexio: sent MPLSCP ConfReq id=0xf1
21:48:20 pppoe,ppp,debug PPPoE-Inexio: MPLSCP open
21:48:20 pppoe,ppp,debug PPPoE-Inexio: BCP open
21:48:20 pppoe,ppp,debug PPPoE-Inexio: CCP lowerup
21:48:20 pppoe,ppp,debug PPPoE-Inexio: CCP open
21:48:20 pppoe,ppp,debug,packet PPPoE-Inexio: rcvd LCP TermReq id=0xa3
21:48:20 pppoe,ppp,debug PPPoE-Inexio: LCP closed
21:48:20 pppoe,ppp,debug PPPoE-Inexio: CCP lowerdown
21:48:20 pppoe,ppp,debug PPPoE-Inexio: BCP lowerdown
21:48:20 pppoe,ppp,debug PPPoE-Inexio: BCP down event in starting state
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPCP lowerdown
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPV6CP lowerdown
21:48:20 pppoe,ppp,debug PPPoE-Inexio: IPV6CP down event in starting state
21:48:20 pppoe,ppp,debug PPPoE-Inexio: MPLSCP lowerdown
21:48:20 pppoe,ppp,debug,packet PPPoE-Inexio: sent LCP TermAck id=0xa3
21:48:20 pppoe,ppp,debug PPPoE-Inexio: LCP lowerdown
21:48:20 pppoe,ppp,info PPPoE-Inexio: terminating...
21:48:20 pppoe,debug,packet ether6: sent PADT to 00:00:00:00:00:00
21:48:20 pppoe,debug,packet session-id=0x16e5
21:48:20 pppoe,ppp,debug PPPoE-Inexio: LCP down event in starting state
21:48:20 pppoe,ppp,info PPPoE-Inexio: disconnected
21:48:20 pppoe,debug,packet ether6: rcvd PADT from F0:1C:2D:2A:1F:EF
21:48:22 pppoe,debug,packet ether6: rcvd PADO from F0:1C:2D:2A:9F:EF
21:48:22 pppoe,debug,packet session-id=0x0000
21:48:22 pppoe,debug,packet ac-name=ix-r4.einsiedlerhof
21:48:22 pppoe,debug,packet host-uniq=0x2003c000
21:48:22 pppoe,debug,packet service-name=
21:48:22 pppoe,debug,packet ac-cookie=5c ee 71 73 6d 38 70 33 02 b8 36 9f 7c 31 20 9f
21:48:22 pppoe,debug ether6: received PADO with unknown host-uniq, dropping
21:48:23 pppoe,ppp,info PPPoE-Inexio: initializing...
21:48:23 pppoe,ppp,info PPPoE-Inexio: connecting...
21:48:23 pppoe,debug,packet ether6: sent PADI to FF:FF:FF:FF:FF:FF
21:48:23 pppoe,debug,packet session-id=0x0000
21:48:23 pppoe,debug,packet host-uniq=0x2203c000
21:48:23 pppoe,debug,packet service-name=
21:48:23 pppoe,debug,packet ether6: rcvd PADO from F0:1C:2D:2A:1F:EF
21:48:23 pppoe,debug,packet ac-name=ix-r4.ffm
21:48:23 pppoe,debug,packet ac-cookie=5c ee 71 73 6d 38 70 33 02 b8 36 9f 7c 31 20 9f
21:48:23 pppoe,debug,packet ether6: sent PADR to F0:1C:2D:2A:1F:EF
21:48:23 pppoe,debug,packet host-uniq=0x2303c000
21:48:23 pppoe,debug,packet ether6: rcvd PADS from F0:1C:2D:2A:1F:EF
21:48:23 pppoe,debug,packet session-id=0x16e5
21:48:23 pppoe,ppp,debug PPPoE-Inexio: LCP lowerup
21:48:23 pppoe,ppp,debug PPPoE-Inexio: LCP open
21:48:23 pppoe,ppp,debug PPPoE-Inexio: LCP timer
21:48:23 pppoe,ppp,debug,packet PPPoE-Inexio: sent LCP ConfReq id=0x6
21:48:23 pppoe,ppp,debug,packet <mru 1480>
21:48:23 pppoe,ppp,debug,packet <magic 0x749e283b>
21:48:23 pppoe,ppp,debug,packet PPPoE-Inexio: rcvd LCP ConfReq id=0xad
21:48:23 pppoe,ppp,debug,packet <mru 1492>
21:48:23 pppoe,ppp,debug,packet <magic 0x6114564>
21:48:23 pppoe,ppp,debug,packet <auth pap>
21:48:23 pppoe,ppp,debug,packet PPPoE-Inexio: sent LCP ConfRej id=0xad
21:48:23 pppoe,ppp,debug,packet PPPoE-Inexio: rcvd LCP ConfAck id=0x6
21:48:24 pppoe,ppp,debug,packet PPPoE-Inexio: rcvd LCP ConfReq id=0xae
21:48:24 pppoe,ppp,debug,packet <mru 1492>
21:48:24 pppoe,ppp,debug,packet <magic 0x6114564>
21:48:24 pppoe,ppp,debug,packet PPPoE-Inexio: sent LCP ConfAck id=0xae
21:48:24 pppoe,ppp,debug PPPoE-Inexio: LCP opened
21:48:24 pppoe,ppp,info PPPoE-Inexio: authenticated
21:48:24 pppoe,ppp,debug PPPoE-Inexio: IPCP lowerup
21:48:24 pppoe,ppp,debug,packet PPPoE-Inexio: sent IPCP ConfReq id=0xf2
21:48:24 pppoe,ppp,debug,packet <addr 0.0.0.0>
21:48:24 pppoe,ppp,debug,packet <ms-dns 0.0.0.0>
21:48:24 pppoe,ppp,debug PPPoE-Inexio: IPCP open
21:48:24 pppoe,ppp,debug PPPoE-Inexio: IPV6CP open
21:48:24 pppoe,ppp,debug PPPoE-Inexio: MPLSCP lowerup
21:48:24 pppoe,ppp,debug,packet PPPoE-Inexio: sent MPLSCP ConfReq id=0xf2
21:48:24 pppoe,ppp,debug PPPoE-Inexio: MPLSCP open
21:48:24 pppoe,ppp,debug PPPoE-Inexio: BCP open
21:48:24 pppoe,ppp,debug PPPoE-Inexio: CCP lowerup
21:48:24 pppoe,ppp,debug PPPoE-Inexio: CCP open
I think the problem is the entry "2 pppoe,debug ether6: received PADO with unknown host-uniq, dropping ". Something is going wrong here. Does anybody have suggestions? I googled a lot and some users are reporting similar problems with their Mikrotik system…
Thanks for the help!
Regards
Toby
