EDIT: I figured out that the order of my firewall rules were causing the issue. Problem solved.
I am attempting to configure the PPTP server on my 750GL. When I am connected to the LAN on my iPhone, I am able to connected quickly to the PPTP VPN using my WAN IP address. When I attempt to connect from my LTE connection, the connection times out and there doesn’t appear to be anything in the Mikrotik log.
I was able to connect to a PPTP VPN server on my Buffalo router via LTE, so I don’t think the ISP is blocking it.
Here are the configuration details:
ip pool add name=VPN-Pool ranges=192.168.0.190-192.168.0.199
# NAME RANGES
0 default-dhcp 192.168.0.200-192.168.0.254
1 VPN-Pool 192.168.0.190-192.168.0.199
ppp profile add name=VPN-Prof local-address=VPN-Pool remote-address=VPN-Pool dns-server=192.168.0.1 use-encryption=required change-tcp-mss=yes
Flags: * - default
0 * name="default" use-mpls=default use-compression=default use-vj-compression=default use-encryption=default
only-one=default change-tcp-mss=yes
1 name="VPN-Prof" local-address=192.168.0.1 remote-address=VPN-Pool use-mpls=default use-compression=default
use-vj-compression=default use-encryption=required only-one=default change-tcp-mss=yes dns-server=192.168.0.1
2 * name="default-encryption" use-mpls=default use-compression=default use-vj-compression=default use-encryption=yes
ppp secret add name=tmbc password=***** service=pptp profile=VPN-Prof
# NAME SERVICE CALLER-ID PASSWORD PROFILE REMOTE-ADDRESS
0 tmbc pptp ***** VPN-Prof
interface pptp-server server set enabled=yes default-profile=VPN-Prof
enabled: yes
max-mtu: 1460
max-mru: 1460
mrru: disabled
authentication: mschap1,mschap2
keepalive-timeout: 30
default-profile: VPN-Prof
ip firewall filter add chain=input protocol=tcp dst-port=1723 action=accept
ip firewall filter add chain=input protocol=gre action=accept
0 ;;; default configuration
chain=input action=accept protocol=icmp
1 ;;; default configuration
chain=input action=accept connection-state=established
2 ;;; default configuration
chain=input action=accept connection-state=related
3 ;;; default configuration
chain=input action=drop in-interface=ether1-gateway
4 chain=input action=accept protocol=tcp dst-port=1723
5 chain=input action=accept protocol=gre
