Solved: Problem: Forward port 443 to different servers
Hello Mikrotik community,
following problem:
I have one external ip address. I want to forward port 443 to server01 or server02. Both are listening to ssh on port 443.
How can I access these servers from the outside ?
Normally I can only define one static NAT rule to forward e.g. to server01.
Is it possible, to define knock rules that will switch the NAT rule to forward to server02 ?
I hope you understand what I wanna do.
Regards
Carsten
maybe it’s better to forward external_ip:2001 to server01:443 and external_ip:2002 to server02:443?.. why do you need such complexity?..
Hi Chupaka,
I have two servers listening on ssh port 443. I have only one external ip address (it’s a privat line).
I must use port 443 for ssh because then I can go through firewalls and proxies (other ports are normally not allowed).
Sometimes I have to access server01 via putty and sometimes I have to access server02 via NXClient (NoMachine).
So I thought there’s a possibility to change the NAT rule “on the fly” via knock sequence or any other means.
Regards
Carsten
well, I’m not sure what knocking you can use if you have only 1 port allowed %)
Hi Chupaka,
I have solved the problem with a linux server behind the firewall.
There’s a knock daemon installed. When I knock with a special sequence it will connect to the Mikrotik router via ssh
and change the to-address of the NAT rule via script for the port 443.
But thanks anyway
Carsten
special sequence of what?..
Hi Chupaka,
with special sequence I mean a combination of sending udp port knocks to the knock daemon of my Linux system.
Regards
Carsten
that’s exactly what I was asking about: how do you use port knocking on udp, if all ports are blocked except 80/tcp and 443/tcp? :slight_smile:
if they are allowed, then you may use something like that:
/ip fi man add chain=prerouting in-interface=WAN dst-address-type=local protocol=tcp dst-port=12001 action=add-src-to-address-list address-list=to-server-1 address-list-timeout=00:00:05
/ip fi man add chain=prerouting in-interface=WAN dst-address-type=local protocol=tcp dst-port=12002 action=add-src-to-address-list address-list=to-server-2 address-list-timeout=00:00:05
/ip fi nat add chain=dstnat in-interface=WAN dst-address-type=local protocol=tcp dst-port=443 src-address-list=to-server-1 action=dst-nat to-addresses=server01_IP
/ip fi nat add chain=dstnat in-interface=WAN dst-address-type=local protocol=tcp dst-port=443 src-address-list=to-server-2 action=dst-nat to-addresses=server02_IP
now you just do ‘telnet IP 12001’ - and then you have 5 seconds to establish SSH connection to port 443 - and it will be redirected to server01. the same with server02 and ‘telnet IP 12002’
Hi Chupaka,
I didn’t say that I have blocked all ports. Of course I forward and nat the udp ports (the sequence) to the Linux server with the knock daemon.
Maybe I have misdescribed it.
I think, that’s exactly what I need. I’ll give it a try.
thanks
Carsten
