Hy all,
I have a problem with a RB153. I try to expand it with a 512MB kingston Compact Flash Card, but when I insert it on the RB153 slot, I lost all my settings. If i reinsert the settings (wireless mode, IP address, exc…) with the CF inserted, it goes all ok, but when I unplug the RB153 from the power source and re-plug it, all changes are lost again! I don’t know how to made work correctly the RB153 with a CF card. Someone has the same problem?
I have not. but it sounds like a volume mount issue.
I would suggest creating a SupOut file for each condition and send it to support. (make sure you describe the issue and clearly ID the SupOut files)
