I’ve been setting up a RB 1100 AH for work to replace our awful netgear jobby.
But I’m stuck, I can’t seem to bridge together switch1 and 2.
I have the following config:
- eth1-master
- eth2-5-slave to eth1
- eth6-master
- eth7-10-slave to eth6
- eth11 is my wan port.
I have 1 bridge (bridge-local) which has eth1-master added too it.
So ports 1-5 route correctly as intended.
But when trying to add the eth6-master to the bridge, it just says “invalid”
Have I missed something?
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 RS ether1-master ether 1500 1598 9498 D4:CA:6D:3C:93:FC
1 S ether2-slave ether 1500 1598 9498 D4:CA:6D:3C:93:FD
2 S ether3-slave ether 1500 1598 9498 D4:CA:6D:3C:93:FE
3 S ether4-slave ether 1500 1598 9498 D4:CA:6D:3C:93:FF
4 RS ether5-slave ether 1500 1598 9498 D4:CA:6D:3C:94:00
5 ether6-master ether 1500 1598 9498 D4:CA:6D:3C:94:01
6 S ether7 ether 1500 1598 9498 D4:CA:6D:3C:94:02
7 S ether8 ether 1500 1598 9498 D4:CA:6D:3C:94:03
8 S ether9 ether 1500 1598 9498 D4:CA:6D:3C:94:04
9 S ether10 ether 1500 1598 9498 D4:CA:6D:3C:94:05
10 R ether11-wan ether 1500 1600 9500 D4:CA:6D:3C:94:06
11 ether12 ether 1500 1600 9116 D4:CA:6D:3C:94:07
12 ether13 ether 1500 1600 9116 D4:CA:6D:3C:94:08
13 R bridge-local bridge 1500 1598 D4:CA:6D:3C:93:FC
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether1-master bridge-local 0x80 10 none
1 I ether6-master bridge-local 0x80 10 none
