I’m trying to mount my routerboard smb share in my ubuntu 12.04.4 LTS, but unfortunally I’m not having success.
Below the sbmtree output, I’ve double checked the password.
yamash@PITCAIRN:/mnt$ sudo smbtree -U SAMBA
Enter SAMBA's password:
LOCAL
\\PITCAIRN PITCAIRN server (Samba 3.6.3, Ubuntu)
\\PITCAIRN\Storage Shared Files
\\PITCAIRN\Web Website
\\PITCAIRN\IPC$ IPC Service (PITCAIRN server (Samba 3.6.3, Ubuntu))
\\CONNOR CONNOR
\\CHARLES
The output of mount:
yamash@PITCAIRN:/mnt$ sudo mount -t cifs -ouser=SAMBA,password=****** \\\\10.0.0.33 /mnt/connor/ --verbose
mount.cifs kernel mount options: ip=10.0.0.33,unc=\\10.0.0.33\,,ver=1,user=SAMBA,prefixpath=mnt/connor/,pass=********
mount error(38): Function not implemented
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
dmesg output:
[255024.486687] CIFS VFS: cifs_mount failed w/return code = -113
[255055.694588] CIFS: the value of the unc= mount option does not match the device string. Using the unc= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead. ((null) != \\10.0.0.33\)
[255055.694603] CIFS: the value of the prefixpath= mount option does not match the device string. Using the prefixpath= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead.((null) != mnt/connor/)
[255055.713890] CIFS VFS: NTLMSSP requires Unicode support
[255055.713919] CIFS VFS: Send error in SessSetup = -38
[255055.714023] CIFS VFS: cifs_mount failed w/return code = -38
[255347.335059] CIFS: the value of the unc= mount option does not match the device string. Using the unc= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead. ((null) != \\CONNOR\)
[255347.335074] CIFS: the value of the prefixpath= mount option does not match the device string. Using the prefixpath= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead.((null) != mnt/connor/)
[255348.364280] CIFS VFS: Error connecting to socket. Aborting operation
[255348.364389] CIFS VFS: cifs_mount failed w/return code = -113
[255857.490337] CIFS: the value of the unc= mount option does not match the device string. Using the unc= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead. ((null) != \\10.0.0.33\)
[255857.490352] CIFS: the value of the prefixpath= mount option does not match the device string. Using the prefixpath= option for now. In 3.10, that option will be ignored and the contents of the device string will be used instead.((null) != mnt/connor/)
[255857.508886] CIFS VFS: NTLMSSP requires Unicode support
[255857.508915] CIFS VFS: Send error in SessSetup = -38
[255857.509025] CIFS VFS: cifs_mount failed w/return code = -38
Can anyone guide me to solve this?
In Windows I have not problem to map this share.
—EDIT—
SOLVED
/etc/fstab
//connor.codex/Files/ /mnt/connor cifs user,file_mode=0777,dir_mode=0777,rw,gid=1000,sec=ntlm,credentials=/root/credentials/connor 0 0
sudo mount -t cifs //10.0.0.33/Files /mnt/connor -o user=SAMBA,password=*,sec=ntlm --verbose
