[SOLVED] Route only HTTP traffic into VPN
Hello!
I am trying to route all HTTP (port 80) traffic coming from the local network into an OpenVPN tunnel between two MikroTik routers.
The reason is that there is a Firewall between the router and the internet that blocks all ports but 443 and 22.
Here you can see a diagram of my setup
All I want is to route all the HTTP traffic of both the Server (that I am calling Bill for clarity sake) and the Mikrotik router into the OpenVPN tunnel, while keeping all the HTTPS traffic on the ether1 interface.
I have read many articles here on the forum that are somewhat related to my problem but to no avail (actually I have just succeeded in locking me out of the Mikrotik).
If you need more info let me know.
Thank you
Giorgio
PS
The VPN is already tested and working
Simplest config can be something like:
add dst-address=0.0.0.0/0 gateway=10.10.12.250 routing-mark=to-vpn
/ip firewall mangle
add chain=prerouting src-address=192.168.10.2 protocol=tcp dst-port=80 action=mark-routing new-routing-mark=to-vpn
add chain=output protocol=tcp dst-port=80 action=mark-routing new-routing-mark=to-vpn
Depending on other stuff you have, it may be better to first mark connections and then mark routing based od connection marks.
Thank you very much for the quick reply. I understand what you are doing and it worked like a charm. I only had to add a NAT masquerade rule for the VPN interface so that the answer from the OpenVPN server can find its way back. Thank you again.
