[Solved] Route wlan3 through vpn (pptp) - Help!
I am trying to configure a solution to route users connected to wlan3 through vpn (pptp).
I created the second bridge, all users connected to wlan3 have separate addresses (192.168.89.0/24) with additional dhcp server.
It does not work and I do not know where the problem is?
Below you can find my config.
[admin15@MikroTik] > export
# aug/15/2016 21:00:33 by RouterOS 6.36
# software id = QPY4-EXUD
add admin-mac=E4:8D:8C:D7:0A:54 auto-mac=no comment=defconf name=bridge
add name=bridge2
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 password=xxx use-peer-dns=yes user=xxx
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=plecak2 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=plecak5 wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:D7:0A:58 master-interface=wlan2 multicast-buffering=disabled name=wlan3 ssid=wlan3 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface pptp-client
add connect-to=x.com.eu disabled=no max-mru=1400 max-mtu=1400 mrru=1600 name=vpn password=xxx user=xxx
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys wpa-pre-shared-key=xxx wpa2-pre-shared-key=xxx
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=pool2 ranges=192.168.89.10-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge lease-time=6h name=defconf
add address-pool=pool2 disabled=no interface=bridge2 name=dhcp2
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge2 interface=wlan3
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=192.168.88.0
add address=192.168.89.1/24 interface=wlan3 network=192.168.89.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.88.246 client-id=1:38:ea:a7:a3:2b:f mac-address=38:EA:A7:A3:2B:0F server=defconf
add address=192.168.88.226 mac-address=00:21:5A:6F:00:CB server=defconf
add address=192.168.88.245 client-id=1:f8:b1:56:b0:e0:3 mac-address=F8:B1:56:B0:E0:03 server=defconf
add address=192.168.89.0/24 gateway=192.168.89.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.89.1 name=router
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=pppoe-out1
/ip firewall mangle
add action=mark-routing chain=prerouting log-prefix="" new-routing-mark=vpn passthrough=yes src-address=192.168.89.10-192.168.89.254
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=pppoe-out1
add action=masquerade chain=srcnat log-prefix="" out-interface=pppoe-out1
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 log-prefix="" out-interface=bridge src-address=192.168.88.0/24
add action=dst-nat chain=dstnat dst-address=!192.168.88.226 dst-address-type=local dst-port=8888 log-prefix="" protocol=tcp to-addresses=192.168.88.226 to-ports=8888
add action=dst-nat chain=dstnat dst-address=!192.168.88.226 dst-address-type=local dst-port=12000 log-prefix="" protocol=tcp to-addresses=192.168.88.226 to-ports=12000
add action=masquerade chain=srcnat log-prefix="" out-interface=vpn
add distance=1 gateway=vpn routing-mark=vpn
/system clock
set time-zone-name=Europe/Warsaw
/system routerboard settings
set cpu-frequency=650MHz init-delay=0s protected-routerboot=disabled
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
After I connected to wlan3 my ping goes through vpn. My public IP is IP of vpn server (nslookup myip.opendns.com. resolver1.opendns.com), but I am not able to open any website.
Where is the problem?
Could you please help me with this topic?
Try modify masquerade rules, set src address in vpn rule and in pppoe rule, remove duplicate pppoe rule
Have a good day!
Are you sure that masquerade rule for pppoe needs the src-address? The internet connection through pppoe works without src-address as below.
I added the src-address (wlan3 users addresses) to the masquerade rule for vpn but internet connection of wlan3 through vpn still does not work.
add action=masquerade chain=srcnat comment="defconf: masquerade" log-prefix="" out-interface=pppoe-out1
add action=masquerade chain=srcnat log-prefix="" out-interface=vpn src-address=192.168.89.0/24
Ok, move vpn masquerade rule to the first position
Have a good day!
Still does not work, but after I connected to wlan3 my ping goes through vpn. My public IP is IP of vpn server (nslookup myip.opendns.com. resolver1.opendns.com), but I am not able to open any website.
Coud someone please check why the routing wlan3 through vpn (pptp) does not work?
add address=192.168.89.1/24 interface=bridge2 network=192.168.89.0
/ip firewall mangle
add action=mark-routing chain=prerouting log-prefix="" new-routing-mark=vpnmark passthrough=yes src-address=192.168.89.2-192.168.89.254
add distance=1 gateway=vpn routing-mark=vpnmark
Solution:
If you want to use the pptp or l2tp is good to turn off the fasttrack in firewall filter rules. You can try to also exclude vpn protocols from fasttrack.
