I just recently upgraded to 6.42.3 and I'm trying out the new configuration style without master ports. I have configured a bridge and added my target port to the bridge, then assigned an IP to the bridge. I can ping across the link just fine. But when I add OSPF or RIP to the bridge interface, nothing happens. I don't see a neighbor relationship form. Both devices are hEX running the same code. Any hints or suggestions are greatly appreciated.
[admin@MikroTik] /routing ospf interface> print detail
Flags: X - disabled, I - inactive, D - dynamic, P - passive
2 D interface=bridge2 cost=10 priority=1 authentication=none
authentication-key="" authentication-key-id=1 network-type=broadcast
instance-id=0 retransmit-interval=5s transmit-delay=1s
hello-interval=10s dead-interval=40s use-bfd=no
[admin@MikroTik] /routing ospf neighbor> print detail
[admin@MikroTik] /ip address> print
ADDRESS NETWORK INTERFACE
2 192.168.90.1/30 192.168.90.0 bridge2
[admin@MikroTik] /ip address> /ping 192.168.90.2
SEQ HOST SIZE TTL TIME STATUS
0 192.168.90.2 56 64 0ms
1 192.168.90.2 56 64 0ms
sent=2 received=2 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
d,
This turned out to be firewall related. There were new default rules that dropped the traffic.
