Solved: Routing Public IP
Let Say Router A have 3 clients on eth1 port with x.x.x.x, y.y.y.y, z.z.z.z public ip and eth1 port have t.t.t.t public ip which is acting as gateway for internal network. now eth2 of router A connected with ISP Router which is Router B’s eth1 with a /30 subnet.
now i want to know the router B’s configuration, that means how router B route those static IPs into the Router A’s internal network
Thanks in advance
With this configuration you need configure:
1.- Route 0.0.0.0/0, gateway (IP from eth1 of router B). On A router.
2.- “masquerade” for internet navigation on Router B.
I think with this configuration you will have intenet navigation. :slight_smile:
Thanks waver
  1. number 1 i already created but i didn’t mention it in previous post. that is a must do option because i am not using nat.
  2. can you elaborate the number 2 more
i am new to routeros, i am just learning. :slight_smile:
this topic is solved. here is the answar:
http://community.ubnt.com/t5/airOS-Software-Configuration/Route-between-subnets-without-double-nat/m-p/633671#M34630
Fantastic.
:slight_smile:
