I have a working IPV6 network. Devices do get SLAAC and DHCP from router advertisement.
I have setup a CAP AX with a simple Access Point configuration. The CAP AX is getting a proper IPV6 connectivity (can ping any IPV6 of the internet)
But, Android 16 connected devices, which are all getting a proper IPV6 address, can only ping and access the advertised /64 network they are in.
The configuration :
add admin-mac=XX:XX:XX:XX:XX:12 auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-557213 \
datapath.bridge=bridge disabled=no name="Master 2Ghz" \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes \
.passphrase=xxxxxxxx
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-557213 \
datapath.bridge=bridge disabled=no name="Master 5Ghz" \
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface="Master 5Ghz"
add bridge=bridge comment=defconf interface="Master 2Ghz"
/ipv6 settings
set accept-router-advertisements=yes
/ip dhcp-client
add interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=bridge request=address
/ipv6 firewall address-list
/ipv6 nd
/system clock
set time-zone-name=Pacific/Noumea
/system identity
set name=AccessPoint-1
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
set allowed-interface-list=*2000011
