[solved] some interfaces in one IP segment
/ interface vlan
add name="v16" mtu=1500 arp=proxy-arp vlan-id=16 interface=eth1 disabled=no
add name="vlan1049" mtu=1500 arp=proxy-arp vlan-id=1049 interface=eth1 disabled=no
/ ip address
add address=192.168.0.250/24 network=192.168.0.0 broadcast=192.168.0.255 interface=eth1 disabled=no
add address=192.168.16.250/24 network=192.168.16.0 broadcast=192.168.16.255 interface=v16 disabled=no
add address=192.168.16.250/32 network=192.168.16.245 broadcast=192.168.16.245 interface=vlan1049 disabled=no
192.168.16.245 have 192.168.16.250 as its default gateway.
I can ping 192.168.16.245 (on interface vlan1049) from MT and from 192.168.0.0/24, but i can’t ping it from the rest of 192.168.16.0/24.
What is wrong with proxy-arp? What should i do to make the MT answer ARP-requests on other interfaces from the same IP segment?
any suggestions?..
normis, uldis, help please!..
from manual:
The router with enabled proxy ARP always answer with its own MAC address if it has a route to the destination.
This behaviour can be usefull, for example, if you want to assign dial-in (ppp, pppoe, pptp) clients IP addresses from the same address space as used on the connected LAN.
does dial-in and vlan has fundamental differences?..
You’re having the same IP address on 2 different interfaces
/Henrik
but all works fine, except that users within one IP segment cannot communicate with each other
maybe power fault (and next reboot of MT) helped, but now all works fine, proxy arp proxies =)
how to test: on neighbour MT Tools → IP Scan, interface → connected to main MT, address range → addresses behind the router.
the result should be all IP addresses, but with the same MAC address of main MT
Diganet
:stuck_out_tongue:
