I was using RB600A. Due to port limitation, I decided to change to replace it with RB2011iLS.
I set public IP to 2xx.1xx.1xx.2/25 to ether1, GW 2xx.1xx.1xx.1 and the rest of the ports are slave switch and bridged. I can ping any other IP within the /25 except .1 which is the router at my ISP. I am using the same configuration as my RB600A and it works on RB600A.
The servers connected to the rest of the ports with the same subnet (/25) can be access from the internet except the IP assigned to my RB2011iLS. Any idea what’s wrong? How and where I should start troubleshooting? Thanks.
May be your provider uses MAC locking. In such case you have to call provider and ask unblock new MAC (some providers allow this to do online. Sometime they charge additional costs for this ^). Or change ether1 RB2011 MAC to the equal on RB600A WAN port one.
For your information, and I did assign the IP to the bridge. The rest of the machine within the same subnet can access to RB2011 and vice versa except .1 which is the ISP gateway.
It is not certain it is really locking it, when the provider uses Cisco equipment it can take quite long before
it switches to a new MAC address because the ARP lifetime is quite long and the outgoing ARP does not
learn from incoming ARP requests. So it could have been it started working when you left it connected for
a couple of hours.
The RB2011 is connected to the up link for more than 48hours and still not working. Anyway, I’ve told the ISP to look into this matter, thanks for dropping by.
