[SOLVED] Tx & Rx rate via SNMP ?
Hello everyone,
I am currently writing a Zabbix template to monitor my RB3011UiAS with SNMP.
I cannot find the oid for Tx rate and Rx rate.
[admin@gw01] /snmp community> /interface print oid
 0  R  name=.1.3.6.1.2.1.2.2.1.2.1 actual-mtu=.1.3.6.1.2.1.2.2.1.4.1
       mac-address=.1.3.6.1.2.1.2.2.1.6.1 admin-status=.1.3.6.1.2.1.2.2.1.7.1
       oper-status=.1.3.6.1.2.1.2.2.1.8.1 bytes-in=.1.3.6.1.2.1.31.1.1.1.6.1
       packets-in=.1.3.6.1.2.1.31.1.1.1.7.1 discards-in=.1.3.6.1.2.1.2.2.1.13.1
       errors-in=.1.3.6.1.2.1.2.2.1.14.1 bytes-out=.1.3.6.1.2.1.31.1.1.1.10.1
       packets-out=.1.3.6.1.2.1.31.1.1.1.11.1 discards-out=.1.3.6.1.2.1.2.2.1.19.1
       errors-out=.1.3.6.1.2.1.2.2.1.20.1
This is weird because in The Dude client, there is an SNMP tab for my device and I can get Tx / Rx rate. Is it calculated from bytes-in and bytes-out ? I cannot afford to do this in Zabbix because it’s way too slow and bloated to be reliable.
Does someone have an idea ?
Regards.
TX and RX are bytes-in and bytes-out. What typically happens is the SNMP server polls the device a number of times for these OID’s and since it knows the difference in time between these two polls, it uses the difference between the numbers received to calculate the bandwidth for that time slice.
Ok, thanks.
Really? I cannot believe Zabbix is that broken. It is standard practice in monitoring software to calculate rates this way!
I just found something interesting here : https://www.zabbix.com/forum/showthread.php?t=27845
There is a builtin calculation for speed in the Zabbix item.
According to documentation :
Store value → Delta (speed per second) - evaluate value as (value-prev_value)/(time-prev_time)
This is exactly what I needed.
