Hi.
I need set user without rights to policy option like user add or delete etc.
Why this user cannot change own password.
Mikrotik show form with password fields and after klick Apply i get info:
Couldn`t change Change Password - not permitted (9)
Router RB2011UAS-2HnD (mipsbe) RoS v 6.5
Regards
P.
Enable ‘password’ policy for this user group.
HTH,
Hi
Only policy is uncheked for this User Group.
Checkbox password is checked - change password is impossible.
Regards
P.
How do you try to change password?
Using Winbox, then ‘System/Password’ I’m able to change it.
If You are trying with ‘System/Users’, double-click on user name, then ‘Password’ button,
it ends with with message ‘Couldn`t change Change Password - not permitted (9)’.
In first case user is changing it’s own password, in second case user is trying to manage users,
but this is not permitted (‘policy’ is unchecked).
HTH,
This is it !
System/Password - working fine.
System/Users - not working - but now i know why.
Thank You !
P.
Getting error couldn’t change interface not permitted (9) pls help
