You edit your post, but is still full of frills and errors.
If you try to correct someone who corrects you, at least make sure you correct well…
If 2 is a number there is no need for “”, if instead it is a string, then consistently the 1 must also be quoted…
And about "check$nwsarr" must be, for the same reason, :set "check$nwsarr" and :set "Down$nwsarr"
I do not have added " (on all places) for not add unreadability on code.
Since someone is not so dumb to use problematic variable names… Or not?
Rightly so, what @Amm0 says is correct.
Without parse, execute and other frills…
:global gev
:if ([:typeof [$gev]] = “nil”) do={:global gev [:toarray “”]}
/system clock
:local datetime “$[get date] $[get time]”
:local nwshost (“Tes1”,“Tes2”,“Tes3”,“Tes4”,“Tes5”,“Tes6”,“Tes7”,“Tes8”,“Tes9”)
:local id (1 + [:len $nwshost])
added for test
:set ($gev->“checkTes2”) 1 ; # for test if work (($gev->“checkTes2”) != 1)
:foreach item in=$nwshost do={
:if (($gev->“check$item”) != 1) do={:set ($gev->“check$item”) 2}
:set ($gev->“Down$item”) $datetime
added for test
:put ($gev->“checkTes2”)
:put ($gev->“DownTes2”)
:put ($gev->“checkTes4”)
:put ($gev->“DownTes4”)
