[solved] wAP LTE kit, LAN connection
Dear Mikrotik,
We have a new wAP LTE kit. https://mikrotik.com/product/wap_lte_kit
As stated there “The wAP LTE also has one 10/100 Ethernet LAN port for your wired devices.” .. so far so good.
After setting up the sim card, there is internet on the wireless network the device provides, but not on the wired Ethernet LAN port.
Is this on purpose, if yes, why?
I would assume, connecting to the internet with LTE as WAN, and both wireless and ethernet as LAN would work out of the box.
  • The WLAN and the LAN devices are on the same network and can communicate with each other, and with the router.
  • I can ping a public ip, 8.8.8.8 on a wireless connected device, but not on a device connected on the wire.
Is this a bug in the initial configuration?
If yes, when would be a fix released? What needs to be set so it works as expected?
If no, could there be a Quick Set preset for this simple scenario - as advertised on the product page?
Please advise as soon as possible, I need to get this configuration done ASAP. I have a deadline, and must provide internet on a wire.
Thank you.
/export config here
# jun/08/2019 16:05:33 by RouterOS 6.44.3
# software id = SP23-66TZ
# model = RBwAPR-2nD
# serial number = 9CE30956266B
/interface lte
set [ find ] band=3,7,20,31,41 mac-address=00:11:22:33:44:56 name=lte1 network-mode=lte
add admin-mac=B8:69:F4:B6:26:02 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-B62603 wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=net
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Budapest
/tool mac-server
/tool mac-server mac-winbox
Are you using the dns provided by the sim? try add 8.8.8.8 and 8.8.4.4 as the dns servers
You can remove the LTE dns from the LTE APNs menu untick Use Peer DNS and default route distance to 1
Or in the DHCP add dns servers into the network
Dear @flynno,
This does not seem to be a DNS issue, as pinging an IP directly over the wire does not resolve…
.. unless I add manually the gateway as route, on my computer.
route add default gw 192.168.88.1 eth0
So it seems that the DHCP server on the wire does not boot up the network connection properly: there is no default route.
I checked the DHCP settings, but cound not find any problems yet.
Finallly found the problem. My bad.
I was testing the network connection on two notebooks. Both of these laptops we used previously to set up CAPSMAN based AP’s and the setup process required connecting to those devices with a static IP, therefore there was a 192.168.88.11 static IP set on the wired devices on both of those notebooks. …
Sorry, my mistake. Thank you for your help!
That’s great glad you got it sorted
