[Solved] WDS mesh
Hi
I have setup in ten mikrotik wds mesh. The problem is that when a device goes under a mikrotik that will have better signal it will not change. Device will have to loose signal to change the mikrotik
Is it possible to fix that?
Thanks in advanced
Try this:
/interface wireless access-list
add authentication=no forwarding=no interface=AP signal-range=-120..-80
add interface=AP signal-range=-79..120
Where AP is your wireless interface
When the signal is between -120 to -80 the device will not connected.
When the signal is between -79 to 120 the device will connected.
You can change of course the -80 and -79 to your needs.
