[solved] winbox on MacOS
Hi guys,
i was trying to run winbox under macosx 10.4.7, macbook pro. I followed your guidelines on the wiki, and winbox starts, connects, downloads plugins, but at the final step, where the main router window should pop up, i always get a “Router disconnected” message. Any heads-up with this? Thanks
Zoltan
Hi
i just downgraded my darwine to 0.9.10, and it works fine.
Same issue here. uncheck “secure mode” checkbox and it will work fine.
Eugene
