Solving a host HW issue with routing?
I have a Yamaha AV receiver that was connected to internet via lan cable, so that I could see it as a cast device from, for instance, Spotify.
Since I’m back from a long travel, my surprise was that the AV was no longer able to get an IP via DHCP from router. After checking a lot of things, even with wireshark, I saw the device is always using a full zeroes as MAC address, and so never getting back an address from router. I tryed updating, downgrading and updating again the firmware and nothing. I guess the network interface has some hw issue right now that avoid using the proper mac address from the physical interface.
I separated the connection into a 10.0.0.0/30 connection of ether5 interface, assigning a fixed ip 10.0.0.2 from the AV, and then bridging Ether5 to the LAN and WAN from the hAP ac2 that I use as router.
With this, at least I can use Yamaha app from the phone to handle some functions of the AV, but still not Spotify or chromecast functions, as well as Net Radio, as I guess they need to route to the internet first. One of the first thing the AV does once getting a live connection, is trying to reach some sites, such as https://yradio.vtuner.com/
Anyway, my idea was to try using the microtik to “NAT” the MAC address and so route the traffic from AV “corrected” to all destinations.
I tried setting some NAT and Firewall rules, but honestly I’m not getting any results.
So I’m here to ask for your help. Do you have any suggestion?
Thanks in advance!
Matteo
