taske
June 30, 2024, 6:53pm
1
i looked thru a few threads already and tried various solutions but i’m having no success. I apologize in advance i realize my question is very basic but im very new to networking and mikrotik in general.
The TLDR version is : i have a mikrotik router at home. I also have a Synology NAS connected. I’ve set up wireguard on my Android phone. I am now facing 2 problems:
The phone connects fine via the wireguard but im getting no traffic to WAN
What rules must i set up if i want to be able to connect to the NAS with phone (via VLC for video streaming) - if im on local home wifi i have no issues connecting via ftps, smb etc.
The basic setup is such:
the home network is 10.20.30.0/24 with the nas being on ip 10.20.30.40
The ip addresses for wireguard are given from a pool of 192.168.33.0/24
Pasting the entire config below:
2024-06-30 20:44:03 by RouterOS 7.12.1
software id = LJPS-M6IC
model = RB750Gr3
serial number = CC210C29124E
add name=LAN_BRIDGE
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add include=all name=LAN
add name=WAN
/interface lte apn
/ip ipsec profile
add name=dhcp_pool0 ranges=10.20.30.2-10.20.30.254
add address-pool=dhcp_pool0 interface=LAN_BRIDGE lease-time=10m name=Dhcp_Lan
/port
set 0 name=serial0
add bridge=LAN_BRIDGE ingress-filtering=no interface=ether2
add bridge=LAN_BRIDGE ingress-filtering=no interface=ether3
add bridge=LAN_BRIDGE ingress-filtering=no interface=ether4
add bridge=LAN_BRIDGE ingress-filtering=no interface=ether5
/ipv6 settings
add interface=LAN_BRIDGE list=LAN
add interface=*8 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=193.168.33.15/32 interface=wireguard1 public-key=\
add address=10.20.30.1/24 comment=LAN interface=LAN_BRIDGE network=10.20.30.0
add address=20.30.40.1/24 interface=*8 network=20.30.40.0
add address=192.168.33.1/24 interface=wireguard1 network=192.168.33.0
/ip dhcp-client
/ip dhcp-server lease
add address=10.20.30.33 client-id=1:c:80:63:be:45:9a mac-address=
0C:80:63:BE:45:9A server=Dhcp_Lan
add address=10.20.30.0/24 dns-server=8.8.4.4 gateway=10.20.30.1
/ip dns static
add address=159.148.172.226 name=upgrade.mikrotik.com
/ip firewall address-list
add address=192.168.11.0/24 list=logatec
add action=accept chain=input comment=“allow wireguard” dst-port=13231
protocol=udp
add action=accept chain=input comment=“allow wireguard traffic” log=yes
src-address=192.168.33.0/24
add action=accept chain=forward in-interface=wireguard1 out-interface=
LAN_BRIDGE
add action=accept chain=forward dst-address=10.20.30.0/24 src-address=
192.168.33.0/24
add action=accept chain=forward src-address=20.30.40.0/24
add action=accept chain=forward dst-address=20.30.40.0/24 src-address=
10.20.30.0/24
add action=accept chain=input comment=“allow established connections”
connection-state=established
add action=accept chain=input comment=“allow related connections”
connection-state=related
add action=accept chain=input in-interface=ether1 protocol=icmp
add action=accept chain=input dst-port=1107 in-interface=ether1 protocol=tcp
add action=accept chain=input dst-port=8291,22,23,21 protocol=tcp
src-address-list=logatec
add action=accept chain=forward out-interface=ether1 src-address=
10.20.30.0/24
add action=drop chain=input comment=“Drop all from WAN” in-interface=ether1
add action=accept chain=srcnat dst-address=192.168.27.0/24 src-address=
10.20.30.0/24
add action=accept chain=srcnat dst-address=192.168.88.0/24 src-address=
10.20.30.0/24
add action=accept chain=srcnat dst-address=192.168.11.0/24 src-address=
10.20.30.0/24
add action=dst-nat chain=dstnat dst-address-list=“” dst-port=1107
in-interface=ether1 protocol=tcp src-address-list=“” to-addresses=
10.20.30.40 to-ports=1107
add action=src-nat chain=srcnat out-interface=ether1 protocol=tcp
src-address=10.20.30.40 src-port=1107 to-ports=1107
add action=masquerade chain=srcnat out-interface=ether1 src-address=
20.30.40.0/24
192.168.33.0/24
add action=accept chain=srcnat src-address=192.168.33.0/24
/ip ipsec identity
/ip ipsec policy
/ip service
set telnet disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Ljubljana
/system identity
set name=taskeDoma
/system note
set show-at-login=no
/system package update
set channel=testing
anav
June 30, 2024, 8:43pm
2
(1) Change this from
add name=WAN
TO:
add name=LAN
add name=WAN
(2) Change this from
add interface=*8 list=LAN <---- this means you have an error by the way…
TO:
add interface=wireguard1 list=LAN
(3) This is the other end of your error.
add address=20.30.40.1/24 *interface=8 network=20.30.40.0
WTFrig are you attempting to do with this subnet ???
Which you failed to disclose???
(4) What is the purpose of this???
/ip dns static
(5) What is the purpose of a private address list entry here, which doesnt exist on your network??
(6) CLEANING UP your firewall rules:
{ default rules to keep }
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
{ admin rules }
protocol=udp
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment=“drop all else” { put this rule in last so you dont lock yourself out }
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
{ admin rules }
add action=accept chain=forward comment=“allow internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“allow wg to local subnet” in-interface=wireguard1 dst-address=10.20.30.0/24
add action=accept chain=forward comment=“allow port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
(7) Fix NAT ( I only see the need for two rules, if you think differently tell me why! )
add action=dst-nat chain=dstnat dst-port=1107 in-interface=ether1
protocol=tcp to-addresses=10.20.30.40
(8) As far as your wireguard client settings the only thing required for allowed IPs is 0.0.0.0/0
Dont forget to have keep alive set to like 35s.
taske
June 30, 2024, 9:03pm
3
(1) Change this from - done
add name=WAN
TO:
add name=LAN
add name=WAN
(2) Change this from - Done
TO:
(3) This is the other end of your error. - This is a remnant of an old config i was toying with, i’ve removed it now.
(4) What is the purpose of this??? - honestly i forgot what this was about, i believe i had some issues with upgrading the firmware and this was proposed somewhere.
/ip dns static
(5) What is the purpose of a private address list entry here, which doesnt exist on your network?? - remnant of an old IPSec i had configured but havent deleted fully, removed it now.
(6) CLEANING UP your firewall rules: - Done
{ admin rules }
protocol=udp
{ admin rules }
(7) Fix NAT ( I only see the need for two rules, if you think differently tell me why! ) - Done
(8) As far as your wireguard client settings the only thing required for allowed IPs is 0.0.0.0/0 - Done
Wireguard setting on Android are: IpAddresses : 192.168.33.15/32
DNS: 8.8.8.8
Port 13231
Allowed Addresses : 0.0.0.0/0
Keep alive 10s
Still no WAN traffic when connected over WG nor do i see the NAS files via VLC
New config below:
2024-06-30 23:04:49 by RouterOS 7.12.1
model = RB750Gr3
add name=LAN_BRIDGE
add name=WAN
/interface lte apn
/port
set 0 name=serial0
/ipv6 settings
set auth=sha1,md5
/ip dhcp-client
/ip dns static
protocol=udp
add action=accept chain=forward comment=“Allow Internet traffic”
add action=accept chain=forward comment=“Allow port forwarding”
add action=accept chain=forward comment=“Allow Wireguard to local Subnet”
dst-address=10.20.30.0/24 in-interface=wireguard1
add action=dst-nat chain=dstnat dst-port=1107 in-interface=ether1 protocol=
/ip service
/system clock
/system identity
set name=taskeDoma
/system note
set channel=testing
anav
June 30, 2024, 9:32pm
4
You didnt make any changes from my recommendations… Suspect you posted your old config??
taske
June 30, 2024, 9:44pm
5
Im confused.
I’ve fixed the Interface lists, NAT rules and edited the FW rules, cleaned up the old IPSec settings and redundant ip addresses. am i missing something?
anav
June 30, 2024, 11:04pm
6
Well for starters you didnt answer ANY of my questions.
What is the purpose of this???/ip dns static
Change this from
TO:
ON your new config you have this…
Your firewall rules are out of order, you have extra rules not required according to your config and requirements. and you allow winbox from the internet which is a no no regardless if you think you are limiting to IP address,
Only access winbox from within the LAN or via VPN etc…
taske
July 1, 2024, 4:59am
7
My formatting might have been poor, sorry. I’ve tried to answer your questions in bold format in the quoted part of your reply.
I believe things should be how you specified but im still getting no internet traffic nor LAN NAS access
2024-07-01 06:51:42 by RouterOS 7.12.1
model = RB750Gr3
add name=LAN_BRIDGE
add name=WAN
/interface lte apn
/port
set 0 name=serial0
/ipv6 settings
set auth=sha1,md5
/ip dhcp-client
add action=accept chain=input comment=“Allow ping” in-interface=ether1
protocol=icmp
protocol=udp
established,related hw-offload=yes
/ip service
/system clock
/system identity
set name=taskeDoma
/system note
set channel=testing
