Some CAPs seen from both WiFi and Wireless CAPSMAN
This is not a new problem, I am just getting around to asking about it. WiFi CAPSMAN sees two MIPSBE APs (boards RBwAPG-5HacT2HnD and RB962UiGS-5HacT2HnT). Both of those APs have the wireless package. I have two other identical APs (same model and board) but WiFi CAPSMAN does not see them. They too have the wireless package. Wireless CAPSMAN sees all 4 of them. WiFi CAPSMAN can successfully upgrade the MIPSE APs, but does not provision them, i.e. it does not show their radios. Why does WiFi see only 2 of the 4 mipsbe APs? Any idea how to make it see all 4 so I could upgrade all my APs from one CAPSMAN?
Please provide configs of all devices involved:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
I will restrict this to one board type.
I'm not sure what you mean by "post between code tags by using the </> button" but I'll try.
Seen by both capsman's
2025-04-30 10:10:03 by RouterOS 7.19rc1
software id = GFDB-9JEH
model = RB962UiGS-5HacT2HnT
serial number = xxxxx
add admin-mac=CC:2D:E0:3F:2C:9B auto-mac=no name=bridge port-cost-mode=short
priority=0x9000
/interface wireless
managed by CAPsMAN
channel: 2412/20-Ce/gn(28dBm), SSID: xxxxx, local forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge
ssid=KGLAN station-roaming=enabled wireless-protocol=802.11 wps-mode=
disabled
managed by CAPsMAN
channel: 5180/20-Ceee/ac(27dBm), SSID: KGLAN, local forwarding
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40mhz-Ce
disabled=no mode=ap-bridge ssid=xxxx station-roaming=enabled
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=sfp1 ] advertise=
10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik
/ip smb users
/routing table
add fib name=""
add bridge=bridge ingress-filtering=no interface=ether2 internal-path-cost=10
path-cost=10
add bridge=bridge ingress-filtering=no interface=ether3 internal-path-cost=10
path-cost=10
add bridge=bridge ingress-filtering=no interface=ether4 internal-path-cost=10
path-cost=10
add bridge=bridge ingress-filtering=no interface=ether5 internal-path-cost=10
path-cost=10
add bridge=bridge ingress-filtering=no interface=sfp1 internal-path-cost=10
path-cost=10
add bridge=bridge ingress-filtering=no interface=ether1 internal-path-cost=10
path-cost=10
add bridge=bridge interface=wlan2
add bridge=bridge interface=wlan1
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set accept-router-advertisements=yes max-neighbor-entries=8192
add interface=ether1 list=WAN
add interface=bridge list=LAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE:39:05:63:8E:F9 name=ovpn-server1
/interface wifi cap
set discovery-interfaces=all enabled=yes
/interface wireless cap
set bridge=bridge discovery-interfaces=ether1 enabled=yes interfaces=
wlan1,wlan2
add address=192.168.1.17/24 interface=bridge network=192.168.1.0
/ip dhcp-client
DHCP client can not run on slave or passthrough interface!
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/system clock
set time-zone-name=America/Denver
/system identity
set name=MTAP-SHP
/system package update
set channel=testing
/system routerboard settings
Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes boot-device=nand-only
/tool bandwidth-server
set authenticate=no
Seen by one capsman (wireless)
2025-04-30 10:07:12 by RouterOS 7.19rc1
software id = YKQF-RKBK
add admin-mac=CC:2D:E0:32:9B:E7 auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
managed by CAPsMAN
channel: 2442/20-Ce/gn(28dBm), SSID: xxxxx, local forwarding
set [ find default-name=wlan1 ] band=2ghz-g/n disabled=no mode=ap-bridge
disabled
managed by CAPsMAN
channel: 5805/20-eeeC/ac(27dBm), SSID: xxxxx, local forwarding
disabled=no mode=ap-bridge ssid=xxxxx station-roaming=enabled
/interface ethernet switch
set 0 cpu-flow-control=no
add name=WAN
add name=LAN
/interface lte apn
wpa-psk,wpa2-psk,wpa-eap,wpa2-eap group-ciphers=tkip,aes-ccm
group-key-update=30m mode=dynamic-keys supplicant-identity=MikroTik
unicast-ciphers=tkip,aes-ccm
/ip smb users
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether1
internal-path-cost=10 path-cost=10
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether2
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether3
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether4
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=ether5
add bridge=bridgeLocal comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridgeLocal interface=wlan2
add bridge=bridgeLocal interface=wlan1
set udp-timeout=10s
/ip settings
/ipv6 settings
add interface=bridgeLocal list=LAN
add auth=sha1,md5 mac-address=FE:5C:D5:EB:7E:38 name=ovpn-server1
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes
interfaces=wlan1,wlan2
add address=192.168.1.12/24 interface=bridgeLocal network=192.168.1.0
/ip dhcp-client
Interface not active
/ip ipsec profile
/ip smb shares
/ipv6 firewall filter
add action=drop chain=forward disabled=yes in-bridge-port=ether3 log=yes
log-prefix=Polisy protocol=tcp
add action=drop chain=forward disabled=yes log=yes log-prefix=Polisy
out-bridge-port=ether3 protocol=tcp
/system clock
/system identity
set name=MTAP-GC
/system package local-update mirror
set enabled=yes primary-server=192.168.1.1 user=admintjk
/system package local-update update-package-source
add address=192.168.1.1 user=xxxxx
set channel=testing
set authenticate=no
/tool sniffer
set file-name=Roku filter-mac-address="34:97:F6:B6:D4:CE/FF:FF:FF:FF:FF:FF,AC:
AE:19:EE:2D:31/FF:FF:FF:FF:FF:FF,C8:3A:6B:F6:89:85/FF:FF:FF:FF:FF:FF"
memory-limit=1000KiB
WiFi capsman only works with those that support the wifi-qcom package. For those AP’s that aren’t seen. Do you have the wireless package installed or the wifi-qcom? (wifi-qcom-ac for wifi 5 or wifi-qcom for >= wifi 6)
Also I looked through your config you posted and the one that can be seen has the line, which indicates that you have wifi-qcom installed
/interface wifi cap
while the one that can’t be seen doesn’t, so I do believe this is your problem
I think you are right but things do not add up. Winbox only shows the wireless package installed for both. However, the one that can be seen by both wifi and wireless capsman has both a wifi and wireless interface in the configuration I posted. The one that can only be seen by wireless only has a wireless interface in the configuration I posted. For the one that can be seen by both, Winbox does not show a WiFi interface in Interfaces or an interface in WiFi but it is in the configuration I posted. The only thing Winbox shows me are wireless interfaces. Any idea where that wifi interface in the posted configuration came from and why I cannot see it anywhere in winbox?
Did some more digging and learned that the wifi-qcom (WiFi capsman) is unsupported by any device with a MIPSBE cpu which both of your units have. The direct quote from the Mikrotik WiFi documentation, “Incompatible: RB4011iGS+5HacQ2HnD-IN (no support for the 2.4GHz interface), Cube 60Pro ac (no support for 60GHz interface), wAP ac (RBwAPG-5HacT2HnD) and all other devices with a MIPSBE CPU”
So that is likely why you can’t see it in packages. I also manually downloaded the extra files to see if it’s included in there which its not. Only thing I could assume is if the package was manually installed somehow.
Yes, I had always understood that wifi-qcom did not work with MIPSBE and I too looked for it in the extra packages. In the early days when routerOS first introduced WiFi capsman, there were instructions to delete some packages, install some packages, etc. I do not remember the exact instructions. Chances are I did not follow those instructions exactly and ended up with a wifi interface where there shouldn’t be one and it has just hung around in the background.
I figured this out. Those that could be seen by wifi capsman had wifi cap enabled on the MIPSBE APs with a discovery interface of All. There are no wifi interfaces but cap can still be configured, enabled and disabled. Once enabled, wifi capsman can see the APs. Although there is nothing that can be configured with wifi capsman, I can upgrade the APs with wifi capsman. Thanks to TrevinLC1997 for looking at the config files and spotting the wifi cap entry.
