Is there any known reseller or Routerboard pro in Montreal, Quebec Canada ?
I m about to buy a routerboard 493g and I m not very familliar with firewalls !
I will need to route 4 Vlans (Internet, Servers, clients, other places connected to the office all on the same Vlan), be sure the exchange serveur still works and configure some VPN connections + VPN peer to peer.
I m affraid I will have some trouble configuring it and I would like to talk to a Dude in Montreal that might come to my place and help configuring it !
Any infos ?
Thank you very much,
Martin L.
I already have a guy in Quebec City, but still 3hours far from here !!
If a big problem accurs and he has to move, that’s gonna be a long wait and a costy ride !!
This guy from Quebec City told me he could have me a 493G but only in 2 weeks as it is a new product that seams really promising !
So he said he will send me a 450g just so that I can make it work for now by the time I get the 493g, and then I will be able to export/import all the config !!
Will that cause any problem or it will transfer perfectly ?
You will have to edit the export of the config before it is imported into the 493G. An export includes things like MAC addresses.
That is good to know !!
But it is still something do-able ?
I mean, I m not an experte in firewall, I will have to work a lot to make it work if I don’t have help near MTL !
So once all the config is done and woking, I don’t want to have a single problem while switching firewall !
I will only have to edit to be sure the mac adress is correct and maybe something else ?
The reste will all work as it is the same routerOS ?
