machack
1
Hello
I have a simple script that erases all IMBOX sms, what I would like is to be able to delete only the ones with blank message field.
:foreach i in=[/tool sms inbox find] do={
:put [/tool sms inbox remove $i ]
This is why if we send sms to our customers mikrotik create blank messages into inbox for each one we send.
some help?
ryz
2
Hi, I have the same problem too.
Sms sent are holded in INBOX dir.
Is it possible to not hold sent messages in INBOX dir ?
100mux
4
#Delete SMS in Inbox
If you need remove only without text messages, you can find message=“”
:foreach i in=[/tool sms inbox find message=“”] do={
eworm
6
Or without loop:
/ tool sms inbox remove [ find where message="" ];
