some help with NAT+no-ip.org
hello
I have started to use DDNS no-ip.org service
when I enter my “website” - I enter the device ,and it working
my only problem is that I can’t enter the router using winbox\www(port 1880)
*** in SSH I can enter the router
what did I did wrong?
thanks ,
when i do the same test, then mine works perfectly.
It would be more useful to see your config (/export compact). The image doesn’t really help.
The input filter chain in /IP Firewall control access to the router itself.
